  • 6 months later...
I was going through GE 4522 bulbs about once a year.
I added a very thin rubber faced aluminum mounting ring to the installation.
I have two 4522 bulbs on the shelf and the old one won't die.it has been four years!
(I fly 80-100 hours a year)
I'd like to switch to LED....but....
Sounds like mine, it lasted 4 or 5 years. Finally, it worked well on dusk preflight and departure; three hours later, coming home to my 3000' field with trees at both ends, I couldn't see the parallel fudge as well as normal. Sure enough, on final the trees were invisible, too. But I knew to hold 700 msl until I could see the green REIL lights, which meant I was past the trees.
Ordered my Whelen Parmetheus the next day. Just turned it off for the second time since May, as I was taxiing in for annual last week.
