rbridges Posted October 9, 2014 Report Posted October 9, 2014 I've been talking to a local shop. he didn't think it would be a big deal since i have the 76A. btw, what are they quoting you for labor? Mine is saying around $500.
Bill Dunn Posted October 9, 2014 Report Posted October 9, 2014 $500 to do the direct swap? We charge 6 hours ($585) to install a new transponder that isn't plug and play.
M20S Driver Posted October 10, 2014 Author Report Posted October 10, 2014 I've been talking to a local shop. he didn't think it would be a big deal since i have the 76A. btw, what are they quoting you for labor? Mine is saying around $500. $500 to do the direct swap? We charge 6 hours ($585) to install a new transponder that isn't plug and play. My shop is estimating around $400-$600. The tray has to be replaced since the data cable to the Garmin 530 interferes with KT76C tray. In addition, the Garmin 530 and 430 need a software update. I think this is reasonable. Maybe
JasonW Posted October 24, 2014 Report Posted October 24, 2014 Anyone had a KT-74 installed in the North Dakota / Minnesota area? I'd be the first for the places I've contacted and the quotes have been high.
Bill Dunn Posted October 24, 2014 Report Posted October 24, 2014 the upgrade is somewhere in the 3k range, most shops do not make any money off of it besides the antenna and coax installation. We bill 40 hours of labor for a GPS/NAV/COM which is just under 4K and Pennsylvania is tax free.
M20S Driver Posted October 31, 2014 Author Report Posted October 31, 2014 Does anyone know of an avionics shop in Northern California that has done this upgrade (KT74 and Garmin 430/530)?
thinwing Posted November 2, 2014 Report Posted November 2, 2014 i have and do not replace the yray..kpc
M20S Driver Posted November 2, 2014 Author Report Posted November 2, 2014 i have and do not replace the yray..kpc Hi thinwing, where was it done?
thinwing Posted November 14, 2014 Report Posted November 14, 2014 Call frank at sterling avionics ,concord ca..k
M20S Driver Posted November 14, 2014 Author Report Posted November 14, 2014 Call frank at sterling avionics ,concord ca..k I called him last week and he seems very friendly and knowledgeable. I am waiting for a quotation from the shop.
rbridges Posted November 14, 2014 Report Posted November 14, 2014 I was supposed to have the kt74 installed today but the unit is back ordered. They said another 1-2 weeks.
thinwing Posted November 14, 2014 Report Posted November 14, 2014 yeah..I am not surprised it is backordered..mine was part of a shipment of 10 last December to aircraft Spruce.after software upgrades...system is working well...getting full tisb ground station traffic info now on portable gdl 39 to portable Garmin 696 in panel mount.Traffic also bluetoothed to ipad...so if you have an existing 430w530w and king 76a or c...this was cheapest solution
thinwing Posted November 14, 2014 Report Posted November 14, 2014 Rbridges..executive autopilots has two in stock..give them a call at ksac... 1
Jerry 5TJ Posted November 14, 2014 Report Posted November 14, 2014 ...With 5.1 there is a bug that prevents manually entering fuel remaining, but the JPI interface continues to work just fine. So only an issue for those without any kind of fuel interface. Just upgraded our 530W to SW 5.10 and yes, it is now impossible to enter the fuel on board quantity. The fuel flow is still reported correctly in the AUX / FUEL PLANNING sub-menu but the totals, quantity on arrival, etc are all useless. As our only fuel totalizer display is the 530W, we're out of luck until the next SW release. Garmin says it will be out "soon" and that's a quote.
rbridges Posted November 15, 2014 Report Posted November 15, 2014 Rbridges..executive autopilots has two in stock..give them a call at ksac... thanks, but it should be here shortly, and they're the ones doing the install. I also need them to do the 76A trade back with BK.
kortopates Posted November 15, 2014 Report Posted November 15, 2014 Just upgraded our 530W to SW 5.10 and yes, it is now impossible to enter the fuel on board quantity. The fuel flow is still reported correctly in the AUX / FUEL PLANNING sub-menu but the totals, quantity on arrival, etc are all useless. As our only fuel totalizer display is the 530W, we're out of luck until the next SW release. Garmin says it will be out "soon" and that's a quote. Confused - what fuel totalizer is interfaced to your Garmin that only includes fuel flow and not fuel remaining like the JPI? At least that's what I assume you are saying. Sent from my iPhone using Tapatalk
BigTex Posted November 26, 2014 Report Posted November 26, 2014 Just upgraded our 530W to SW 5.10 and yes, it is now impossible to enter the fuel on board quantity. The fuel flow is still reported correctly in the AUX / FUEL PLANNING sub-menu but the totals, quantity on arrival, etc are all useless. As our only fuel totalizer display is the 530W, we're out of luck until the next SW release. Garmin says it will be out "soon" and that's a quote. Yep... that happened to me as well on my 430W. Just waiting now for 5.11 which they say will come out sometime this year... not holding my breath. For me that's a critical setting as I run my fuel flow through my 430W but they don't give a $hit.
BigTex Posted November 27, 2014 Report Posted November 27, 2014 Well, if you ask you shall receive! 5.20 was released yesterday (11/25). http://garmin.blogs.com/aviationalerts/2014/11/service-bulletin-1461-gns-400w500w-series-software-upgrade-to-main-software-version-520.html And they list the fuel on board issue as being resolved!
rbridges Posted December 8, 2014 Report Posted December 8, 2014 called the avionics shop. The original backorder was until November. A new date for February was just given. Anyway, I called up Sarasota Avionics and am having one sent to my work. They had 3 in stock, but sold one while I was on the phone with them. Anyway, install date is set for 12/19 at the local shop.
M20S Driver Posted December 15, 2014 Author Report Posted December 15, 2014 I have contacted a few avionic shops and it seems to me that they are not up to speed on this installation. I am moving away from KT74 and may consider Garmin 330es. I noticed Garmin price for 330es is around $3600 down from $4000+.
M20S Driver Posted December 16, 2014 Author Report Posted December 16, 2014 Can you elaborate? It is a new transponder, but it is still "just a transponder," You would think anyone with Mode S installation experience and knowledge should be able to install it? I was just about ready to go with a KT-74. Your post makes me want to search for a shop with successful KT-74 installations ... and go there ... There are multiple software upgrades on Garmin side as well as KT74 side. I think there is not enough money in the upgrade to excite the shops. In addition, none of the shops that I talked to had done a Garmin 430/530 integration or were familiar with the STC.
ArtVandelay Posted December 16, 2014 Report Posted December 16, 2014 For $1600 difference in price I would pick the KT74, once it's working you don't have to upgrade firmware if there is integration problem 1
ArtVandelay Posted December 16, 2014 Report Posted December 16, 2014 I still have some time before I pull the trigger on this. Just going to keep my eyes and ears open until then. Some shops are suggesting going with a GDL -88 and leaving the current Mode C ... To get traffic etc on the GPS display. Budget permitting, I really want to do both a 1090ES (to comply with ICAO Standards flying outside the U.S.) and a GDL-88 (to get ASD-B displayed on the GPS). Nothing cheap to buy on this thread! The savings on the KT-74 may just be what enables us to do the GDL-88? I'm going to have same dilemma, ideally you would have switch to get best of both worlds. KT74 requires an airspeed switch, don't know if 88 does, and the 88 by my itself can be used in anonymous mode, if worried about user fees in the future I. need to do some research
