Stefanovm Posted May 18, 2010 Report Posted May 18, 2010 I knew someting was missing. I will try to find the parts mentioned. The repair and parts manuals were not very helpful. I also thought that a safety wire solution would work. I am glad to see the suggestion. It will require the cushion to be removed. The other solution suggestions are also appreciated. Thanks.
carusoam Posted May 18, 2010 Report Posted May 18, 2010 If someone hasn't already said it. Welcome... :) David
