The cams are worn out on my Mooney M20J fuel tank caps.  They don't snap flat anymore.  New caps are more than $400.  Wow!  Best price that I've found (so far) for used caps that still have some snap left in them is $175 each.  Part number is 431-9R.   Can the cams be repaired?   Thanks.
I'm willing to bet all you need is a screw adjustment to the shaft nut as Jose suggests. Replace the small o-ring while you're all it.
