Door pops on take off - '67 M20F
Anyone have this issue?  It just started a couple weeks ago.  I completely stripped the weather seal off and replaced it but that didn't do anything.  We opened up the door and couldn't see anything wrong.....ideas????
Link to comment
Share on other sites
On mine when I first got it the pin at the main latach did not engage on my first flight home.  The door did not pop open completly but you could see light around the door.  It happened a few more times on other flights but I learned that I needed to make sure the handle rotated all the way forward to ensure a complete latch.  Since then no problems
Link to comment
Mine does the same if you don't give it that little extra force on the handle.  Also make sure you're pulling consistantly inward on the door when latching.
Link to comment
Yes, the door latch needs to be adjusted. Movement of the aircraft causes negative pressure, which causes the latch to let go. Often it is only one of the two latches that let's go, but in trying to close the door the pilot fully unlatches the door. It is difficult to close in the air because of the pressure wanting to hold it open. A&P can fix.
Link to comment
