Nico1 Posted January 14 Report Posted January 14 Opened up panels for the 100 hr lube AD and noticed that it looks like the floor gear down indicator is chafing against the floor. Does that need lubrication and/or adjusting (how to adjust?)?
N201MKTurbo Posted January 14 Report Posted January 14 You have to access all of that from the top. Take up the carpet, remove all the tape, take off the screws and you are there. 1
Nico1 Posted January 14 Author Report Posted January 14 25 minutes ago, N201MKTurbo said: You have to access all of that from the top. Take up the carpet, remove all the tape, take off the screws and you are there. Thanks! does it need lubing or adjusting? I did not find any reference on servicing it in the Service Manual
N201MKTurbo Posted January 14 Report Posted January 14 Just now, Nico1 said: Thanks! does it need lubing or adjusting? I did not find any reference on servicing it in the Service Manual Normally not. If you left it alone, you would see about twice that wear in another 50 years. If it is really bugging you, you can take it all apart, clean and maybe repaint the markings and polish out the plastic. It will keep you busy for a weekend and it will look wonderful when you are done. 2
