outermarker Posted March 11 Report Posted March 11 Does anyone use an inner tube with a 70-degree stem on their main gear? Were you also able to keep the dust cover on without a conflict between the two? This would be the type of dust cover that uses only a center screw for attachment. thanks! albert Quote
Andy95W Posted March 12 Report Posted March 12 I use this one: https://www.aircraftspruce.com/catalog/lgpages/aero_06-03303.php 70° stem and uses the air-stop butyl rubber. I don’t use the dust cover hub cap anymore, but the valve stem looks like it should fit nicely under it. Quote
