druidjaidan Posted December 12, 2023 Report Posted December 12, 2023 Considering making an offer on a 231 in central AZ. I'm based way up in WA and it isn't close enough to really push for LASAR or TopGun that I would if it was a CA plane. There's a MSC at KCHD that will be my default, but I figure I should see if there are any locals that would recommend someone, someplace else? Likely going to be a full annual for the pre-buy given its annual is due soon.
KLRDMD Posted December 12, 2023 Report Posted December 12, 2023 Tucson Aeroservice at KAVQ maintains a lot of Mooneys and always took good care of mine.
Jetpilot86 Posted December 12, 2023 Report Posted December 12, 2023 I used Chandler Aviation @ KCHD for a Bravo prebuy recently. Frank is who I worked with there and strongly recommend them. I did not buy the aircraft I sent to them because of what they found.
N201MKTurbo Posted December 12, 2023 Report Posted December 12, 2023 Frank is a good guy. You will be fine with him.
Tommooney Posted December 12, 2023 Report Posted December 12, 2023 Frank at Chandler does my annuals. He's a good guy and his staff are good too..
