Marc_B Posted January 22, 2023 Report Posted January 22, 2023 My start power indication isn't working (test button lights it so not a bulb) and I was looking over the Mooney wiring schematic and see that the Start Power wire on the annunciator (WD02D20) traces back to a fuse somewhere after the starter solenoid. Not sure where that fuse would be located (engine compartment)? I was going to take a look and try to track it down to check it...any chance any of you know where this fuse is located and what type of fuse it is?? Start power on annunciator à wire WD02D20 à clamp(shown below) pin 18 àWD02C20 à FUSE WD02B20 to starter solenoid WD01B20.
PT20J Posted January 23, 2023 Report Posted January 23, 2023 I would expect the fuse to be near the solenoid to protect the wire to the annunciator. In my M20J, the solenoid is inside behind the circuit breaker panel. 1
Fly Boomer Posted January 23, 2023 Report Posted January 23, 2023 49 minutes ago, PT20J said: I would expect the fuse to be near the solenoid to protect the wire to the annunciator. In my M20J, the solenoid is inside behind the circuit breaker panel. My SMM is gracious enough to tell me "The starter solenoid is located on the cabin side of the firewall" but there is a lot of stuff back there. The IPC shows it pictorially, but not relative to anything else. Is there any other documentation where I could have looked up the info you provided above? 1
Aerodon Posted January 23, 2023 Report Posted January 23, 2023 Just fixed mine (86 M20K), the fuse is near the starter solenoid on the back of firewall , in front of the circuit breakers. Not fun getting in there. It could be the fuse, or one of the wires has broken off. Aerodon 1
PT20J Posted January 23, 2023 Report Posted January 23, 2023 22 minutes ago, Fly Boomer said: My SMM is gracious enough to tell me "The starter solenoid is located on the cabin side of the firewall" but there is a lot of stuff back there. The IPC shows it pictorially, but not relative to anything else. Is there any other documentation where I could have looked up the info you provided above? I don't think so. I just noticed it when the panel was apart getting the new avionics installed. Fortunately, I never had to mess with it. One of the frustrating things about Mooneys is that it seems like every part I need to service was the first part they started adding other parts around when they built the airplane.
Fly Boomer Posted January 23, 2023 Report Posted January 23, 2023 12 minutes ago, PT20J said: I don't think so. I just noticed it when the panel was apart getting the new avionics installed. Fortunately, I never had to mess with it. One of the frustrating things about Mooneys is that it seems like every part I need to service was the first part they started adding other parts around when they built the airplane. We used to say while working on certain parts under the hood of a car "you have to start disassembling at the tail light lens". 1
Marc_B Posted January 27, 2023 Author Report Posted January 27, 2023 To circle back around… the fuse for the start relay in the M20K Encore is in engine compartment under top cowl by firewall on left. WAY easier to access than buried behind the copilot side panel. Replaced the fuse and voila the start power indication on annunciator lights up with starter. I really like easy victories. Too bad those aren’t the most common!!
PT20J Posted January 27, 2023 Report Posted January 27, 2023 This was clearly a mistake. Send a note to Mooney and they will create an ECO (Engineering Change Order) to relocate that to someplace less accessible. 2
