ODL Posted July 19, 2022 Report Posted July 19, 2022 I have a 2009 mooney acclaim that I am trying to figure out how to adjust tension and or change the belt on. It look to be a factory AC system installed by premier per mooney specs. I can't figure out how the tensioner works.
Guest Posted July 19, 2022 Report Posted July 19, 2022 6 hours ago, ODL said: I have a 2009 mooney acclaim that I am trying to figure out how to adjust tension and or change the belt on. It look to be a factory AC system installed by premier per mooney specs. I can't figure out how the tensioner works. This should help. Clarence
carusoam Posted July 20, 2022 Report Posted July 20, 2022 Welcome aboard ODL! Always helps to have a copy of the service manual…. And a connection to M20Doc! Best regards, -a-
ODL Posted July 21, 2022 Author Report Posted July 21, 2022 Thank you very much. Got it apart not sure what I was doing wrong the first time. Found the bearing in the idler sheave assembly is bad and ruined the shouldered bolt that holds it in. Can you point me in the right direction for parts?
carusoam Posted July 21, 2022 Report Posted July 21, 2022 2 hours ago, ODL said: Thank you very much. Got it apart not sure what I was doing wrong the first time. Found the bearing in the idler sheave assembly is bad and ruined the shouldered bolt that holds it in. Can you point me in the right direction for parts? Where are you located? Typically for parts… contact your local MSC. If you don’t have a local MSC, an MSC in California can be recommended for you… The Mooney web site lists all of the MSCs world wide… The MSCs coordinate with the factory to obtain rare parts… Hopefully that is an off the shelf automotive part, and not something that needs to be made… Search for Dan at Lasar… Dan is awesome at finding Mooney parts and shipping globally… Best regards, -a- 1
