NotarPilot Posted May 12, 2022 Report Posted May 12, 2022 I have a relatively new ignition switch and keys for sale if you want to go that route. It came out of my plane during my panel rebuild. Quote
carusoam Posted May 12, 2022 Report Posted May 12, 2022 Note for @Jpravi8tor above (ignition switch and keys) -a- 2 Quote
Jpravi8tor Posted May 13, 2022 Author Report Posted May 13, 2022 I’m still holding out hope the previous owner can find the key, next I’m consulting a locksmith I really don’t want to try to change that switch. Quote
N201MKTurbo Posted May 13, 2022 Report Posted May 13, 2022 On 5/9/2022 at 7:50 AM, A64Pilot said: My 1946 Cessna has two toggle switches, one for each mag, the starter is operated via a pull cable that first engages the starter bendix, then closes big contacts on the starter. No AD I have one of those on my 56 172. It works great after I rigged the cable and lever properly. It is a Holly choke cable…. Must be factory, that’s what was there when I bought it. Quote
Jpravi8tor Posted May 13, 2022 Author Report Posted May 13, 2022 I was able to remove the baggage lock that matched the main entry door lock and have 2 keys made for $17.50 at my local locksmith, I just hope the starter switch is the same... Quote
Hank Posted May 13, 2022 Report Posted May 13, 2022 2 hours ago, Jpravi8tor said: I was able to remove the baggage lock that matched the main entry door lock and have 2 keys made for $17.50 at my local locksmith, I just hope the starter switch is the same... Why only two??? Keys to my plane: a set for me a spare set for me a set for my wife a set for my IA a "loaner set" on a keychain with my N number a spare set waiting for one of these to disappear . . . Keys are cheap, what $1.50-$2 each? I've done the locksmith thing, and the big box store thing, all worked well. Quote
Jpravi8tor Posted May 13, 2022 Author Report Posted May 13, 2022 2 keys to start off with, if they work on the main entry door and the ignition then yes I will make four hundred and eleven copies but not yet.... 1 Quote
Guest Posted May 14, 2022 Report Posted May 14, 2022 7 hours ago, Jpravi8tor said: 2 keys to start off with, if they work on the main entry door and the ignition then yes I will make four hundred and eleven copies but not yet.... Leave my set tied to the oil filler tube. I’ll stop by and pick them up later. Clarence Quote
rbp Posted May 14, 2022 Report Posted May 14, 2022 $29 AirTag is cheap insurance. phone reminds me if I leave it behind. Press a button in the app and it beeps. Quote
Jpravi8tor Posted May 14, 2022 Author Report Posted May 14, 2022 Well the keys worked in the main entry door and baggage but not the ignition! who wants to send me old keys to try? Quote
