Anyone have this switch or red cover available? The plastic switch tabs are broken on mine. :(
Thank you
Freddy
How does one identify klixon? I have a '97 Ovation...Also, what material do you use for printing? Thanks
Freddy
Freddy
F,
easiest way… post a pic of what you have…
Or find a Klixon on the web and compare….
The switches are nicely marked… but, once in location they are hard to see the markings…
Sensata/Klixon/Texas Instruments….. this should be close enough for identification purposes…. Compared to other switches…
https://www.sensata.com/sites/default/files/a/sensata-20tc series-single phase rocker type actuator-datasheet_1.pdf
Mine are ABS.  An acetone-based paint sticks well to them.  Nylon might be better, but is difficult to paint.
This is what Klixon covers look like from the back side.
Edited by AH-1 Cobra Pilot
18 hours ago, V1VRV2 said:
I just had one removed from my Ovation 2 panel. Let me see if the avionics shop still has it. Will get back to you on Monday.
Excellent! :)
1 minute ago, philip_g said:
I would have guessed that the o are eta switches? A little silicone on the switch cover to hold it in place and it'll probably work for years if you can't find one
I think you are correct. I was thinking that either silicone or epoxy (more concerned as this as it would be hard to remove) would do the trick but would like to have a backup in case these do not work. I may just go ahead and order the printed type and give it a try.
Freddy
Freddy
For what it's worth I ordered a set for my klixons only to find about half of mine glued on already. Go figure.
For awhile someone sold 3d printed eta covers. You'd have to sand and paint yourself but if you found the file I could print them for you
What I did on a previous plane with eta switches was sand and paint the cover red, then used a label maker to print a label with black letters on clear label tape. Put that on the switch and clear coat over it. Then my mechanic glued the broken switch in place and I never used it. Lol.
Edit here: https://www.shapeways.com/product/BVM7ZU8CK/switch-cover-klixon-20tc-v0-6-smooth-front
Edited by philip_g
In case it turns out to be an ETA switch:
https://www.shapeways.com/product/YR7FSMMJW/mooney-rocker-switch-cover-quot-eta-quot-type
I replaced a bunch of mine with these.  They're nylon and do require some sanding and finishing work if you want to stencil and paint them, but I found that the labels from my labelmaker are the same width as the top and bottom faces, so I just printed the text on them stuck them on and they work/look fine
