Prestonalton Posted June 1, 2021 Report Posted June 1, 2021 Hey yall, so my wife just got her ppl (in a 172) and she would like to fly the Mooney. Only problem is that she's about 5'2" and can't reach the rudder pedals at all. We have pushed the seat all the way forward with cushions below and behind her, but still no luck. Does anyone have any solutions to this problem? She's still about 3-5 in from even touching them. Quote
Guest Posted June 1, 2021 Report Posted June 1, 2021 Rudder pedal extensions are available in 1.5” and 3” lengths. Clarence Quote
carusoam Posted June 1, 2021 Report Posted June 1, 2021 Preston, Expect the three inch extensions to work... often, people mention their inseam details with what size extension works for them... Best regards, -a- 1 Quote
Guest Posted June 1, 2021 Report Posted June 1, 2021 From the J model IPC, but the parts and concept are the same. Clarence Quote
Prestonalton Posted June 1, 2021 Author Report Posted June 1, 2021 32 minutes ago, M20Doc said: Rudder pedal extensions are available in 1.5” and 3” lengths. Clarence Two questions: 1. Do they also go on the passenger side (without brakes)? 2. Where can you find these for sale? Quote
Guest Posted June 1, 2021 Report Posted June 1, 2021 Any Mooney MSC can get them, there are also drawings for them here somewhere. They’re only applicable to rudder pedals with brake pedals. Clarence Quote
Guest Posted June 1, 2021 Report Posted June 1, 2021 I found this on a search. It looks like it could attach to the copilot rudder bar. You would of course need some sort of approval. Clarence Quote
PT20J Posted June 2, 2021 Report Posted June 2, 2021 1 hour ago, M20Doc said: From the J model IPC, but the parts and concept are the same. Clarence Those are the 1.5" Here's the Mooney drawing showing both the 1.5 and 3". Note if you order from Mooney, the 1.5" extensions have parts for two pedals (i.e., a complete set for the pilot) whereas the 3" extensions are only for one pedal so you have to order two. Rudder Extension Drawing 720115.pdf 2 Quote
