Missile=Awesome Posted October 9, 2020 Report Posted October 9, 2020 23 hours ago, Missile=Awesome said: Prop off now. Thanks for the preventative reminder. Belt changed. So mine doesn’t have a belt. Duh says I. After Clarence posted I asked my A&P (that I said put a new belt on while prop is off). He said ok... I asked if we had a belt and he said he was messing with me. I call shenanigans 1 Quote
Missile=Awesome Posted October 9, 2020 Report Posted October 9, 2020 1 hour ago, M20Doc said: If yours looks like this one, you have a gear driven alternator. Clarence Hey, did u steal my Missile?! Quote
Skydancer2992 Posted October 9, 2020 Report Posted October 9, 2020 My M20E Lycoming belt has the Gates symbol next to the part number. This belt is loose and the alternator is adjusted to max tightness. The belt appears to be 26" on the inside circumference. Not sure if it has stretched over time or maybe the Plane Power alternator needs a different one. Quote
carusoam Posted October 9, 2020 Report Posted October 9, 2020 Sometimes... A second alternator may be belt driven... check to see if a second alternator got installed... during the annual... Belts get loose over time... as some stretch is normal... this is probably covered in the install procedures... for how tight the belt should be upon installation, and how tight it should be a few hours later... if re-installing the belt, no additional stretch would be expected... New belt materials don’t stretch like the old day’s belts... loose belts begin slipping... this can cause some voltage challenges... as it slips more, the belt starts getting warmer... When it slips just the right amount... it gets too hot and fails... So... if you have a noticeably loose belt... check it’s part number... something doesn’t seem quite right... otherwise a bracket may have not been replaced during the alternator installation... (got any spare parts that came with that?) PP thoughts only, not a mechanic... Best regards, -a- Quote
Guest Posted October 9, 2020 Report Posted October 9, 2020 9 hours ago, Missile=Awesome said: So mine doesn’t have a belt. Duh says I. After Clarence posted I asked my A&P (that I said put a new belt on while prop is off). He said ok... I asked if we had a belt and he said he was messing with me. I call shenanigans Yours should have one of these to drive the alternator. There are S/B’s covering them, they are known to slip and improper installation can lead to failure. Clarence Quote
Missile=Awesome Posted October 9, 2020 Report Posted October 9, 2020 11 hours ago, Missile=Awesome said: So mine doesn’t have a belt. Duh says I. After Clarence posted I asked my A&P (that I said put a new belt on while prop is off). He said ok... I asked if we had a belt and he said he was messing with me. I call shenanigans My A&P’s sense of humor. This is his installation photo he sent me 1 3 Quote
JimB Posted October 9, 2020 Author Report Posted October 9, 2020 And just to follow up, I got a Lycoming belt and installed it last night along with this shiny propeller!! Makes my old girl look 20 years younger! Still have to finish it up and balance it this weekend but I had to share. 3 Quote
amillet Posted October 9, 2020 Report Posted October 9, 2020 1 hour ago, Missile=Awesome said: My A&P’s sense of humor. This is his installation photo he sent me Check the invoice to see if he charged you for a new belt 1 1 Quote
tmo Posted October 9, 2020 Report Posted October 9, 2020 Isn't that a belt from 4Q14? ;-) So the q becomes if he got a discount because the belt was new old stock... 1 Quote
Guest Posted October 9, 2020 Report Posted October 9, 2020 10 hours ago, Missile=Awesome said: My A&P’s sense of humor. This is his installation photo he sent me Tell him that it will never fly, that’s a Cessna belt. Clarence Quote
kmyfm20s Posted October 9, 2020 Report Posted October 9, 2020 10 hours ago, Missile=Awesome said: My A&P’s sense of humor. This is his installation photo he sent me See now that you have a spare belt your guaranteed to never need it:) 1 Quote
Missile=Awesome Posted October 10, 2020 Report Posted October 10, 2020 11 hours ago, amillet said: Check the invoice to see if he charged you for a new belt Brian and I have had a two decades plus relationship. I trust him and Roy with my and my families life Quote
MikeOH Posted October 10, 2020 Report Posted October 10, 2020 13 hours ago, Missile=Awesome said: My A&P’s sense of humor. This is his installation photo he sent me He forgot the safety wire! Quote
carusoam Posted October 10, 2020 Report Posted October 10, 2020 Sort of a belt and suspenders approach to things... Only belt and gears instead... Thank your mechanic... he has your back covered! Or your front? Best regards, -a- 1 Quote
