hmasing Posted September 27, 2020 Report Posted September 27, 2020 Hey, Mooniacs! I redid my interior upholstery last summer and replaced all the original foam in the seats. I've also added sheepskin covers, which are great to keep the sweat down to a minimum. The issue I'm facing is that in a long flight (> 2 hours) I find my butt starts to REALLY hurt. I often fly 5+ hour legs and have gotten a memory foam insert to go under my Brad Pitt Lookalike Buttocks, but it's not cutting it. Anyone have recommendations for seat cushions that may help out for the long rides? Part of the issue I'm facing is that in my '68F I sit more horizontally than vertically, so my knees are kind of high relative to my hips. Thanks! Quote
Shiny moose Posted September 27, 2020 Report Posted September 27, 2020 I would try very hard foam under your sheepskin and see if that helps, I cannot handle soft seats for more than an hour, had my seat foam relpaced with very stiff non memory foam and my butt thanked me Quote
LANCECASPER Posted September 27, 2020 Report Posted September 27, 2020 24 minutes ago, hmasing said: Hey, Mooniacs! I redid my interior upholstery last summer and replaced all the original foam in the seats. I've also added sheepskin covers, which are great to keep the sweat down to a minimum. The issue I'm facing is that in a long flight (> 2 hours) I find my butt starts to REALLY hurt. I often fly 5+ hour legs and have gotten a memory foam insert to go under my Brad Pitt Lookalike Buttocks, but it's not cutting it. Anyone have recommendations for seat cushions that may help out for the long rides? Part of the issue I'm facing is that in my '68F I sit more horizontally than vertically, so my knees are kind of high relative to my hips. Thanks! https://www.oregonaero.com/seating-systems/seating-systems-overview You may need some lumbar support. 1 Quote
carusoam Posted September 27, 2020 Report Posted September 27, 2020 Lance’s recommendation also has insight on how to build up various layers of foam to achieve the most comfort... A highly refined seat to match the highly refined Brad like buttocks should work pretty well... A few MSers have had the same(?) challenge... There are pics around here of people designing and Gluing and sawing foam parts... To fit under their existing seat covers or when adding to their new seat covers... Funky 3D designs show up with giant side bolsters.... perfect for the cork screw at Laguna... where lateral gs are important... Best regards, -a- Quote
kmyfm20s Posted September 28, 2020 Report Posted September 28, 2020 I was talking to a neighbor that has his shop next to me. He races formula 1000 cars. He was showing me how they make their custom molded race seats with foam and plastic bags. They then use spray contact cement to cover them with material. They are virtually rock hard but he’s says since they are molded that they are supper comfortable as a result of the support. Since the seat bottoms of my Eagle are simply velco’d on in place I was going to make a seat bottom this way and try it out. Quote
coinneach Posted September 28, 2020 Report Posted September 28, 2020 My non-aviation-related $0.02: You want the firmest possible cushion. Softer means your sitbones will press through the foam and come to rest on the seat pan. My Vulcan 900 has a very firm Mustang seat and I can ride it all day. The squishy OEM seat, I'm squirming after an hour. Quote
carusoam Posted September 28, 2020 Report Posted September 28, 2020 Possibly a foam in place packaging solution... (Karson’s idea above...) I guess at name spelling all the time... sometime I am even close... if I remember the name at all... https://www.foam-in-place-systems.com Packaging your butt for long distance traveling... Great for shipping sensitive items... PP thoughts only, not a professional packaging engineer... Best regards, -a- 1 Quote
pwhicks Posted September 28, 2020 Report Posted September 28, 2020 I would look into a Purple Simply Seat cushion. They designed those to help people in wheel chairs. Sent from my iPhone using Tapatalk 1 Quote
kmyfm20s Posted September 29, 2020 Report Posted September 29, 2020 23 hours ago, carusoam said: Possibly a foam in place packaging solution... (Karson’s idea above...) I guess at name spelling all the time... sometime I am even close... if I remember the name at all... https://www.foam-in-place-systems.com Packaging your butt for long distance traveling... Great for shipping sensitive items... PP thoughts only, not a professional packaging engineer... Best regards, -a- Nailed it! 1 Quote
chriscalandro Posted September 29, 2020 Report Posted September 29, 2020 How dare you accuse your seats of not being of a comfort level that your buttox may not rest upon them indefinitely! It must be because of the blasphemous removal of the original gold standard cushioning. How dare you do such a thing. Quote
