So I took my Bravo to an MSC to get an oil change and and the run up was notified the RPM on the Moritz is only working at high RPM/once warm. Haven’t had any issues in the past with it. Pulled back in the shop to diagnose and the sensor/plug is in the mag held with just a zip tie. The shop tried everything they could to fix the cable/sensor but have had no luck. RPMs will show on the Moritz once warmed up but nothing when low. With no replacement parts available, the MSC was willing to install a EI RPM gauge at no cost to me (since it wasn’t having issues prior tot the oil change).  I’m waiting to get it back this week, but the MSC has done everything they can to make it work so now I’ll have a separate RPM garage and my clock moved over to the pax side. It’s a temporary fix but once one is gone on the Moritz it may start downhill. The could not figure out the issue with either the sensor/cable/or Moritz gauge itself But looks like I’ll now have a separate RPM reader for the Bravo. Is a JPI930 now in my future??? :wacko:
Yes.
Unfortunately, the Moritz company left no forwarding address...
However, if you act quickly...
There is a set of Moritz gauges around here recently for sale...
Don’t wait, I sense the price increasing...
The Moritz were the ultimate analog and digital combination... the JPI or EI are even better...
Collecting data for later review is all the rage.
Best regards, and good luck!
2 hours ago, carusoam said:
Yes.
I asked my MSC and he didn’t think a new Moritz or connector would solve the issue as they couldn’t really figure out what part Was faulty. I did want to replace with another Moritz but he couldn’t be positive it would fix the issue.
1 hour ago, Cruiser said:
is it the indicator gauge or the pickup sensor on the mag.
I would think the indicator gauge as the mag itself was sent for a 500 hr inspection.
Some of the pick-up sensors were the culprits for going bad...
And they were really expensive too...
Compared to every JPI and EI that essentially needs to do the same thing...
Makes you want to build an owner supplied part for that... :)
Since the indicator works, i.e. it shows RPM after the engine warms up ? It would seem that part is working.
Since the mags were worked, i.e. they were removed and serviced then reinstalled. It would be the most likely place to look for a problem.
The pickup sensor is not part of the mag. It screws into a port and "picks up" magnetic signals from the rotation of the mag parts. It should be easy enough to remove this pickup and have it checked. These are third party parts purchased by Mooney. There should be a part number replacement in the parts manual for your air frame.
This issue came up before the mags were pulled for inspection.  Since the RPM issue couldn't get fixed, I had them pull the mags for inspection since the plane was already there..
3 hours ago, flysamo said:
had tried to fix the moritz in my ovation, after 4 tries, put in a jpi 900 and problem fix
I have a JPI700 now.  Can't say I'm a fan of a separate RPM gauge, but a new JPI maybe on my horizon soon.
Might be the cable grounding on the engine block. That was what caused issues with mine. I wrapped mine with covering and the problem went away.
5 hours ago, thinwing said:
It’s a common Hall effect sensor on your right mag.I think that might be a slick part...
I do have slicks.
It’s a simple wire connection to the right magneto.The hall sensor used is common to other tachometers....you may have a simple broken wire under the heatshrink on the halls effect sensor screwed to the side or the right magneto.
