Background: Installed and configured TailBeacon without issue a week ago, but previous flight ATC complained about my transponder!  So, naturally my test flight barely got off the ground; ATC couldn't see my transponder at all.  Fast forward to last Saturday...installed used KT76A ($100).  But, no time to do a test flight.
So, yesterday (Sunday) I had to fly the plane a short distance for its annual.  Flight was to be about 15 minutes but tower had me maneuvering all over prior to landing; flight ended up being 25 minutes.  I never got above 4000.
Anyway, I thought, "what the heck" I'll run a PAPR.  Much to my surprise it came back with 0 errors of any kind.
Is that all I need, even though I didn't follow the flight profile protocol?  I've never been quite sure what constitutes a completely 'approved' install past the log entry and 337.
IOW, am I good to go for Jan. 1?
You are good for Jan 1.  Technically a PAPR isn't required.  It was only requrired for the rebate.  Since you have a clean one you now know you are 100% functional and good for Jan 1.  I installed mine the first of the year (skybeacon) and I still pull PAPRs periodically to monitor and make sure it's still good.
If you swapped out a transponder you probably need a new certification,.
