clh Posted December 5, 2019 Report Posted December 5, 2019 HI all My mechanic asked me if I had or could find a form 337 for the installation of a GDL-82 ADS-B. Does anyone have one to share? Quote
Andy95W Posted December 5, 2019 Report Posted December 5, 2019 Installed Garmin GDL-82 IAW SA02573SE. ----------------------Nothing Follows----------------- That's all that is required for an STC'ed alteration. Everything else such as parts, approvals, and Instructions for Continued Airworthiness are included in the STC instructions. (I got the STC number above from the Aircraft Spruce website. You might want to double check it.) Quote
bradp Posted December 6, 2019 Report Posted December 6, 2019 I don’t have one in front of me, but my Garmin STCs always have the same basic boilerplate- Installed garmin STC AW123456XYZ in accordance with Garmin STC installation manual 010-123456-00 Rev X and AC 43.13 1B Ch 11. Post installation checks satisfactory. Electrical load analysis performed and satisfactory. Aircraft W&B and equipment list revisions entered. ICA AFMS and POH supplement placed in aircraft. End. Not an IA / AP. All the stuff about electrical load analysis, etc is included in the STC manual so redundant. They just tend to be included as a formality I suppose... 1 Quote
bradp Posted December 6, 2019 Report Posted December 6, 2019 Here is one for my G5 installation Quote
Baker Avionics Posted December 6, 2019 Report Posted December 6, 2019 On 12/5/2019 at 8:54 AM, clh said: HI all My mechanic asked me if I had or could find a form 337 for the installation of a GDL-82 ADS-B. Does anyone have one to share? Shoot me an email and I have one for you!!! Quote
OR75 Posted December 9, 2019 Report Posted December 9, 2019 On 12/5/2019 at 8:54 AM, clh said: HI all My mechanic asked me if I had or could find a form 337 for the installation of a GDL-82 ADS-B. Does anyone have one to share? Any certified A&P should know how to fill a 337 to sign a 337 , your A&P mechanic needs to have an IA Having said that ... what could be so "special" about the GDL-82 that makes him want to see how a 337 is completed ? I am curious .... 1 Quote
clh Posted December 9, 2019 Author Report Posted December 9, 2019 He thought I had one in my plane. He very rarely works on avionics. This was the first one he has done for the GDL-82. Quote
RLCarter Posted December 9, 2019 Report Posted December 9, 2019 56 minutes ago, clh said: He very rarely works on avionics. 337’s are for any major alterations from what I’ve been told, not just avionics. And, I thought 337’s needed to be filed by an IA? I’ll go ahead and add the disclaimer that I might be talking out of place Quote
Baker Avionics Posted December 9, 2019 Report Posted December 9, 2019 1 hour ago, RLCarter said: 337’s are for any major alterations from what I’ve been told, not just avionics. And, I thought 337’s needed to be filed by an IA? I’ll go ahead and add the disclaimer that I might be talking out of place You are correct, partly, a Certified Repair Station can also approve one as well. 1 Quote
Baker Avionics Posted December 9, 2019 Report Posted December 9, 2019 2 hours ago, clh said: He thought I had one in my plane. He very rarely works on avionics. This was the first one he has done for the GDL-82. Did that help out? Quote
OR75 Posted December 9, 2019 Report Posted December 9, 2019 3 hours ago, clh said: He thought I had one in my plane. He very rarely works on avionics. This was the first one he has done for the GDL-82. if he rarely works on avionics, i would worry about his/her ability to do the work (wiring and setup) rather than the paperwork The paper work is very much standard and applies to anything that is installed based on an STC (basis for installation - in this case the STC - , refer to the install manual, w&b was completed, ..... , and requirement for CAW) Quote
DMM Posted December 9, 2019 Report Posted December 9, 2019 I'm not an A&P but I sometimes pretend to be one on the internet. Check out the attached 2017 technical paper the FAA issued to clarify the FAA 2016 memo concerning ADSB installations. The technical paper has a very detailed sample 337 to use as a go-by. Cheers ADS-B_Out-In_Installation_Tech_Paper(9-25-17).pdf Quote
clh Posted December 10, 2019 Author Report Posted December 10, 2019 1 hour ago, Baker Avionics said: Did that help out? Yes, thanks Quote
Winker Posted August 1, 2020 Report Posted August 1, 2020 Here the link that will give you all you need to certify using the GDL 82 in other aircraft. Garmin GDL® 82 Service Bulletin 1769: Initial Issuance of STC for Installation of Garmin GDL 82 in Mooney M20( ) Series STC SA02573SE | Manualzz Quote
carusoam Posted August 3, 2020 Report Posted August 3, 2020 Welcome aboard Winker! Nice link. Best regards, -a- Quote
