I have read the AD which refers to SB M20-190B Part I, II and III.
At the risk of enduring the wrath of manual Johnson bar owners, I would like to get a sense of the cost of this AD from those who have complied with it.
I am in the buying process for an 1970 M20F with electric landing gear.
thanks
thanks
Quote: edgargravel
Austin:
No wrath.  Just sadness.  Some know.  Some don't..........Wink
BTW:  Good luck with sorting this out (no kidding this time..)Laughing
Austin
From Memory, on my 69F. The AD year to year is not much money, just lube the motor. When inspcetion time comes, take the plane to a MSC to remove and inspcet the gears. I think it was $500.00.  My gears were bad, I had a choice of 20:1 gears stock for $500.00, or the 40:1 gears $1000.00 plus laber to install, another $500.00. All told about $2000.00.
Tom at Top Gun did mine, Laser would be another great shop to get them. I have had my plane at both shops for work or parts. Don Maxwell in Texas has a great rep, as does Wilmar in Minn.
The 40:1 gears are a little slower, 6 or 7 seconds instead of 3 seconds, they don't slam into the gear wells, just seems to be less stress on the system. I am very pleased with the 40:1 gears.
Ron
Quote: N9154V
Austin
Ron
The 40:1 gears are a good idea. I have seen M20s with  a doubler installed on the belly cross member were the motor is mounted. I'm not saying that it's a 20:1 thing, there are other factors that could stress the system, but slower equals less stress which is almost always preferable.
I think it appears antiquated and unrefined to passengers. However, those of us who know...know better!
Quote: Shadrach
Too funny and yet a bit true... ....  There's no substitute for the very tactile feedback one gets from using their right arm as an actuator...
On the aviating dot com website about a week later, I related this story and three other Johnson bar drivers admitted to "never having had this happen to them - and it never will again.."
....One point for the electric gear systems.
Quote: Shadrach
Merely the refuge of "men" who don't know what it feels like to have a large shaft to manipulate.  WinkEmbarassed
Quote: Shadrach
Make that 4 other Johnson bar drivers, but I'n not sure this a point for electric gear...It's no more difficult to forget and you have one less visual clue.
This is why the manual gear Mooneys are worth the same as electric gear ones. Because the manual gear is simple and works well, the electric is easier to use but has a potential 3000$ worth of stuff to go wrong between the actuator, gearset, and landing gear relays.
Quote: Hank
But we are all vulnerable to the Mooney-equivalent of PEBKAC--what would that be? PEBPAC??
Quote: Hank
 Hmmm, let's see . . . Visual clues for gear position . . .
1) Position of round, white selector [up vs. Down] is quite noticeable, and almost at eye level. I double-check it by feel on final, just in case.
2) Green light for down, below the selector; orange light for up, beside the selector. All at the very top of the panel.
3) Mechanical indicator in the floor, lit at night, that works even when after total electrical failure and an emergency extension.
Count 'em off for Johnson bars, and see who has "one less" visual clue. Wink  But then again, I don't have an oversized forearm or skinned knuckles to worry about, and I can store approach plates, my Flight Guide and a beverage between the seats. The biggest problem I have is the little rocker under the switch that turns the landing light off when I'm in the pattern and drop the gear at night--I gotta remember to turn it back on.
