Michael Williams Posted May 3, 2019 Report Posted May 3, 2019 Any Mooney pilots that have put together a successful system to record in-cockpit video on a smartphone with ATC and Intercom audio mixed into the video stream? I know there are a lot of GoPro flyers doing it that way, but I'd like to use my iPhone to do such and its apparently a bigger problem than it seems. There's even a YouTube video "hack" on building a box to be able to do so. I know one pilot who does this with ease with his Android, but I even struggled today trying to plug an Droid into the system. I have the splitter cord that ads the 3mm male pin plug into the smartphone...but even that setup doesn't do the trick. Any feedback? Many thanks, Michael in Santa Rosa (M20C - N79390) Quote
Ned Gravel Posted May 3, 2019 Report Posted May 3, 2019 Michael: See the following. Both recorded on an iPhone with an audio connection. However the current cabling is from sporty's. see https://www.sportys.com/pilotshop/nflightcam-iphone-intercom-audio-interface-cable.html This help? . 1 Quote
carusoam Posted May 19, 2019 Report Posted May 19, 2019 Ned, That is a great Mooney video! Some things escaped my timely reading... Thanks for sharing it. Best regards, -a- Quote
320KPH Posted May 26, 2019 Report Posted May 26, 2019 with a conventional camera I found that a mini tie clip mic in the headphone was the best all around for comms and ATC. DC headset, no noise cancelling. pluggging into the unused comms jack you could hear a lot of electronic noise, like the trnasponder and stuff... You can get a fisheye lens adaptor for the smartphone too, which I found made my cockpit vids heaps better... Quote
