Hi.  I am looking for a M20 spinner dome (or complete spinner assembly).  The following Spinner assemblies should all work.  They are found on planes using a Hartzell HC-C2YR or HC-C2YK constant speed propeller:
assembly #835-20 (dome #C-2426)
assembly #835-33 (dome #C-1904-3)
assembly #103585 (dome #103582)
assembly #835-58 (dome #103937)
I need something inexpensive.  Aesthetics are not important (I will repaint), as long as it is not structurally damaged/cracked.  Thanks!
Jarod
773-398-1967
The spinner is actually going on a Bellanca Cruisair that has the same O-360 engine/prop combo (per a one-time STC), as many of the Mooney M20's.  If your spinner is from a plane with a Hartzell HC-C2YK (or C2YR) prop, it likely is one of the part #'s I listed and will work for me.  Bellanca folks can't help me on this one, so I'm reaching out far and wide.  Thanks!
Jarod
773-398-1967
Posted this for a friend some time ago.  Pretty sure he still has it.  Call him if interested, he doesn’t do computers.  https://mooneyspace.com/topic/28116-fs-hartzell-composite-spinner/?tab=comments#comment-463771
  • 3 years later...
14 hours ago, KCBluesman said:
I have a C-2426 spinner dome, free of cracks, free of damage, for sale.
619-394-7575
Since the post you're replying to is almost four years old, you'll want to ping or quote the person who requested the spinner so they get notified. @Jarod O
