Marauder Posted October 5, 2018 Report Posted October 5, 2018 I ended up spending, $4.65 in o-rings... I hope the guy buying your airplane didn’t read that :-)Sent from my iPhone using Tapatalk Pro
Guitarmaster Posted October 5, 2018 Author Report Posted October 5, 2018 Just now, Marauder said: I hope the guy buying your airplane didn’t read that :-) Sent from my iPhone using Tapatalk Pro Hehe... had already done the bottom part of it. AS near as I can tell, LASAR is charging $49 for the exploded view drawing of the selector.
Marauder Posted October 5, 2018 Report Posted October 5, 2018 I work with my I/A on stuff like this so I don't screw it up. I heard that if you screwed this up, you would run really lean of peak
Guitarmaster Posted October 6, 2018 Author Report Posted October 6, 2018 Only if you have LED nav lights! I heard that if you screwed this up, you would run really lean of peakSent from my iPhone using Tapatalk Pro Sent from my Pixel 2 XL using Tapatalk
carusoam Posted October 6, 2018 Report Posted October 6, 2018 Neil, if you went with a bulleted or numbered list... your response would have been perfect! Blue stains on or near the tank switch... you are seeing a small amount of fuel leaking out into the cabin... What you don’t see is a whole lot of air running into the fuel system... until your FF gauge starts reading really wacky numbers... -a- 1
