markejackson02 Posted July 19, 2018 Report Posted July 19, 2018 Does anyone have an installation manual for the CI-156 antenna? Specifically looking for a template to make a new gasket. Thx
Marauder Posted July 19, 2018 Report Posted July 19, 2018 Does anyone have an installation manual for the CI-156 antenna? Specifically looking for a template to make a new gasket. Thx I don’t have the manual for the CI-156 but I do have the gasket from the CI-156 that I removed and replaced with the CI-196. Here they are side by side. You’re more than welcome to the old gasket if that will help. PM your address if you want it and I’ll stick it in the mail. Sent from my iPhone using Tapatalk Pro
RLCarter Posted July 20, 2018 Report Posted July 20, 2018 You can lay the gasket on a copier or scanner then just email it
markejackson02 Posted July 20, 2018 Author Report Posted July 20, 2018 I found a data sheet that had a scaled drawing of the bottom of the CI-196 which I assume will work. Being a CB before popping for a new antenna.
LARRYMAC Posted January 14, 2020 Report Posted January 14, 2020 On 7/19/2018 at 6:56 PM, Marauder said: I don’t have the manual for the CI-156 but I do have the gasket from the CI-156 that I removed and replaced with the CI-196. Here they are side by side. You’re more than welcome to the old gasket if that will help. PM your address if you want it and I’ll stick it in the mail. Sent from my iPhone using Tapatalk Pro Do you still have the CI-156? I could use one if it's in good condition.
carusoam Posted January 14, 2020 Report Posted January 14, 2020 Welcome aboard Larry... I saw @Marauder around here earlier... The other resource for pre-owned antennas is @Alan Fox... Best regards, -a-
MB65E Posted January 14, 2020 Report Posted January 14, 2020 Please Don’t use the gasket!! Have a nice bead of Proseal around the base after you reinstall it. -Matt
Aerodon Posted January 15, 2020 Report Posted January 15, 2020 On 7/19/2018 at 4:25 PM, markejackson02 said: Does anyone have an installation manual for the CI-156 antenna? Specifically looking for a template to make a new gasket. Thx DallasAvionics.Com has all the spec sheets including footprints. Aerodon
