Recently had a flight were it seemed I had to constantly chase the trim, usually up. It may have been the conditions but I did not some free play in my trim wheel. Do these require adjustment? If so how? I really don't know how these work.
Be sure that’s the yoke shaft panel feedthrough bearing is lubed such that your yoke moves freely in and out.  I find that this makes a big difference, not just in trim, but also my landings.
There is a trim brake screw below the trim wheel. You can tighten it, if it is installed. It is there to stop the trim from being back driven by the tail.
I am sure you are gently lifting the tail on the walk around.   There should only be 1/4 to 1/8 of play.   Start with the simple stuff first.
It took two annuals, but I got a "your trim is smoother than mine"  from an A&P Mooney safety pilot.    Cleaning and lubing each U joint.  There are about 5-6 of them.  Lubing the jackscrew in place.   Cleaning and lubing the trimwheel chain.   Done in place with a brush.   40 year old grease is just gunky stuff.
