wburger1 Posted June 23, 2018 Report Posted June 23, 2018 Anyone else have problems with their Garmin 340 buttons. I have to push the com and nav buttons several times to get them to come on and off. Any suggestions? Tried re-seating it and that did not help. Thanks. Quote
ArtVandelay Posted June 24, 2018 Report Posted June 24, 2018 Try electronic cleaner, spray and repeatedly press the buttons. Quote
wburger1 Posted June 24, 2018 Author Report Posted June 24, 2018 Do you disassemble the front cover of the 340 or just spray it in the panel as is? Quote
ArtVandelay Posted June 24, 2018 Report Posted June 24, 2018 Try it without disassembling, if it doesn’t work, then take off the front plate. Quote
wburger1 Posted June 26, 2018 Author Report Posted June 26, 2018 I will be back to my Mooney next week and try that. Thank you. Quote
LANCECASPER Posted June 27, 2018 Report Posted June 27, 2018 perfect excuse to upgrade to a slide in ps engineering audio panel http://www.ps-engineering.com/ 2 Quote
Ned Gravel Posted June 27, 2018 Report Posted June 27, 2018 1 hour ago, LANCECASPER said: perfect excuse to upgrade to a slide in ps engineering audio panel http://www.ps-engineering.com/ +1 1 Quote
Piloto Posted June 27, 2018 Report Posted June 27, 2018 Never had a problem with my 36 years old KMA24 audio panel. José 1 Quote
carusoam Posted June 27, 2018 Report Posted June 27, 2018 Somewhere around here is a discussion on Garmin buttons... not sure which device they were on... but cleaning and exercising them was key... Best regards, -a- Quote
Jim Peace Posted July 1, 2018 Report Posted July 1, 2018 had the same issue. I think my shop swapped it for another from Garmin or had mine overhauled. Works like new now. Quote
wburger1 Posted July 5, 2018 Author Report Posted July 5, 2018 Well I cleaned it and I still have a few buttons that do not work. Thinking of getting a PMA8000G. 2 Quote
Andy95W Posted July 5, 2018 Report Posted July 5, 2018 On 6/27/2018 at 12:27 AM, Piloto said: Never had a problem with my 36 years old KMA24 audio panel. José Quote
