RobertE Posted March 6, 2018 Report Posted March 6, 2018 I’ve got the pneumatic speed brakes from Precise Flight. In normal weather they operate fine but when it gets to near freezing they extend a bit slowly but sufficiently (say 5 seconds from full down to full up) but retract very, very slowly (30-60 seconds). Anyone experience something similar or have an opinion as to root cause? Thanks. Quote
BorealOne Posted March 6, 2018 Report Posted March 6, 2018 (edited) Sorry - just noticed that yours are pneumatic, so reposting. My electric ones function very well in -20. Can't speak to pneumatics, but Boyle's Law applies. Edited March 6, 2018 by BorealOne Quote
Nomad Pilot Posted March 6, 2018 Report Posted March 6, 2018 What is the pneumatics services with? If it’s shop air you might have a small icing condition. Try purging the system and try servicing it with nitrogen. Sent from my iPhone using Tapatalk Quote
kortopates Posted March 6, 2018 Report Posted March 6, 2018 I’ve got the pneumatic speed brakes from Precise Flight. In normal weather they operate fine but when it gets to near freezing they extend a bit slowly but sufficiently (say 5 seconds from full down to full up) but retract very, very slowly (30-60 seconds). Anyone experience something similar or have an opinion as to root cause? Thanks. Pretty common actually with these older brakes. It could be moisture at the bearings but more likely the conduit cables may be in very poor shape and need replacing. They're stiffer in the cold so I'd look there first. Look up in the wheel wells for any cracking.Sent from my iPhone using Tapatalk 1 Quote
Piloto Posted March 6, 2018 Report Posted March 6, 2018 (edited) Avoid extending them during icing conditions because they may not retract. Try lubricating them with WD-40. José Edited March 6, 2018 by Piloto Quote
jetdriven Posted March 7, 2018 Report Posted March 7, 2018 WD40 for everything. WD40 is not a lubricant and has no place on an aircraft. https://www.popularmechanics.com/cars/how-to/a6064/wd-40-vs-the-world-of-lubricants/ Quote
N201MKTurbo Posted March 7, 2018 Report Posted March 7, 2018 13 minutes ago, jetdriven said: WD40 for everything. WD40 is not a lubricant and has no place on an aircraft. https://www.popularmechanics.com/cars/how-to/a6064/wd-40-vs-the-world-of-lubricants/ It's not like it's useless. It's good for degreasing your landing gear. I use it for spraying down my screws before I put them back in. It makes them easier to get out the next time. I use it for stuck screws, which I havnt had in a long time. I use it on the hangar door. Quote
jetdriven Posted March 7, 2018 Report Posted March 7, 2018 (edited) So is Mineral Spirits. not a lubricant either, but a solvent. Edited March 7, 2018 by jetdriven Quote
Piloto Posted March 7, 2018 Report Posted March 7, 2018 (edited) Check this: https://www.wd40.com/ and this: https://en.wikipedia.org/wiki/WD-40 José Edited March 7, 2018 by Piloto Quote
jetdriven Posted March 7, 2018 Report Posted March 7, 2018 yeah, the only use for "aircraft" was "keeps model aircraft hinges from sticking." And your point is? Quote
Piloto Posted March 7, 2018 Report Posted March 7, 2018 30 minutes ago, jetdriven said: yeah, the only use for "aircraft" was "keeps model aircraft hinges from sticking." And your point is? By 1965 it was being used by airlines including Delta and United; United, for example, was using it on fixed and movable joints of their DC-8 and Boeing 720s in maintenance and overhaul. José Quote
Andy95W Posted March 7, 2018 Report Posted March 7, 2018 And the A&P mechanics in 1965 would wash their hands in MEK. Thank God we've progressed a bit since then. Quote
Tony Starke Posted March 7, 2018 Report Posted March 7, 2018 11 hours ago, jetdriven said: WD40 for everything. WD40 is not a lubricant and has no place on an aircraft. https://www.popularmechanics.com/cars/how-to/a6064/wd-40-vs-the-world-of-lubricants/ The long-term active ingredient is a non-volatile viscous oil which remains on the surface to which it is applied, giving lubrication and protection from moisture. -wikipedia seems it is a lubricant Quote
Oldguy Posted March 7, 2018 Report Posted March 7, 2018 Use the lubricant/solvent of your choice to clean your cables if they appear to be in good condition. I had one sticking on retraction, and a good cleaning/lubing took care of it. If they are cracked or in poor condition as @kortopates describes above, they need replacing. Unfortunately, if there is anything else of a somewhat major issue, it is likely you are out of luck as Precise no longer supports them. Quote
