thinwing Posted January 25, 2018 Report Posted January 25, 2018 1 hour ago, Jerry 5TJ said: For a mere 1 AMU more you can add a Flight Stream 210. Then you can type waypoint names on your tablet’s keyboard and send flight plans to the 530W via Bluetooth. Or you can edit flight plans graphically. Either is way better than the 530W’s “twist-twist-push” data entry. And with the FS210 you get a “free” solid state AI to backup that spinning gyro in the panel. Not to mention adding victor air way capability! 2 Quote
jaylw314 Posted January 25, 2018 Report Posted January 25, 2018 2 hours ago, thinwing said: Hi there..I have a copy of Max's flying the 530 that I found very helpful Jolie... Especially using obs mode for hold setups and entry's...pm your address (Jana prob has it somewhere?)And I will send it along...ps..how many hours on your AI/vac pump? There is also a pretty good YouTube video that uses the Garmin training simulator Quote
mooneygirl Posted January 27, 2018 Author Report Posted January 27, 2018 On 1/25/2018 at 10:21 AM, thinwing said: Hi there..I have a copy of Max's flying the 530 that I found very helpful Jolie... Especially using obs mode for hold setups and entry's...pm your address (Jana prob has it somewhere?)And I will send it along...ps..how many hours on your AI/vac pump? That would be swell. AI/Vacuum was overhauled about 3.5 years ago, which would have been conservatively 300 hours ago. Funny because when I took this photo I hadn't started up yet. When I did we found the suction tube was re-mounted backwards. My AI was doing a dance! Quote
mooneygirl Posted January 28, 2018 Author Report Posted January 28, 2018 Hi all, I have some avionics/instruments for sale due to my upgrade. I would rather sell to someone I know vs Ebay, so I thought I would post. All were removed from my airplane in working order, except #7 which I purchased and never installed. Photos are posted in Avionics for sale forum. Just a heads up in case anyone is looking. 1) KX 155 TSO no GS, with tray. s/n 56958 p/n 069-1024-00 [Ebay completed sales: $875-1100] 2) King KI203 VOR/LOC indicator s/n 4836 p/n 066-3034-00 [Ebay completed sales: $200-495] ------------Would be willing to bundle 1 & 2 for $1200--------- 3) Narco Transponder: AT 50A with tray s/n 34904 [Ebay completed sales: $200-250] 4) Narco Transponder: AT 150 TSO with tray and wiring s/n 18398 [Ebay completed sales: $200-250] 5) King KN 64 DME p/n 066-1088-00 s/n 14249 [Ebay completed sales: $425-1395] 6) Garwin one-piece engine cluster p/n 220-166-09 [Ebay completed sales: $200-250] 7) Garwin individual components engine cluster p/n 22-169-08 [I purchased for $220 plus shipping] Quote
M20F-1968 Posted January 28, 2018 Report Posted January 28, 2018 Just a very basic reminder, but one that catches pilots new to the 430/530/650/750 units. Always be sure that the CDI button is set for GPS or VLOC matching the type of approach you are flying. This mistake can be deadly. The other common mistake is not setting the Course direction for an ILS approach. John Breda 1 1 Quote
Jerry 5TJ Posted January 29, 2018 Report Posted January 29, 2018 On 1/25/2018 at 12:24 PM, jaylw314 said: I've never heard of or looked into the FS210, sounds like an interesting way to spend more money... Ah, that's why. You're stuck with Foreflight, Apple and Garmin for everything Yep, I’m stuck with a well-integrated multi-vendor suite that works well. 1 Quote
