What is going on with Foreflight updates?  Seems like I am downloading hundreds of charts about every week.  Current list ids for 239 products.  I just finished a similar number over the weekend.  Not sure if some are the same or not.
Is it me  or is something strange going on with FF.   Is this somehow related to the patent infringment issue?
I just went through an update cycle with nothing unusual, so I suspect the Bryan is correct. Check to make sure you only have marked for download what you really want. Now, it's possible that some memory corruption issue caused the app to select the whole set by mistake, rather than just your normal load, so if you suspect this is the case just send a note to team@foreflight.com and they can look into it.
