I am needing to make a crate to ship my prop out.   Without me going across town into a cold hangar.   Does anyone have the dementions of a two blade m20j prop.   I know less than 74" diameter.   But what about height and width?
High there...look if you are sending out a prop for overhaul etc...that shop has boxes out the wazoo..typically they send guys around airports within 20 /30 miles for pickup...call the overhaul people
I am not using a local shop.   So I will need to build a crate.   I may also sell the prop when it comes back to offset the cost of a new prop.  So I will definitely need a crate.
Correct!!!  I called and asked if they wanted it back and they said no, so I asked around and one of the three mechanics on my field gladly took it.
-Seth
15 hours ago, N803RM said:
Ask the prop shop for a credit for your prop as is.   Mine did, they gave $1400.00 for the blades, the hub was an AD due hub.  I went for the new Scimitar.
Ron
Even a run out blade has value in the experimental market.
-Robert
I had 26 years and 1500 hrs on an overhaul with new blades.  Hub may have been 47 years old with a total of approx 4500 hours on it.  I was told that a mooney B model out of Corona was going to get my blades and a B hub.
Ron
I'm really thinking we got off tangent here.    I simply asked dementions for a crate.
In case anyone needs to know in the future...
The prop is aprox 74" long.. with the bolts sticking out of the flange  it is 12 inches high, and aprox 8 inches wide.
I picked up 4  1x12" boards, and cut them off to 78" and made the crate out of that.
I had to drill holes in the bottom  for the bolts in the flange to stick into to gain the 1/2" I needed to get the dome of the hub low enough to not smash into the cover.
My crate yielded internal dementions  @  9 3/4 wide 11 1/4 high and 76 1/2 inches long.
