I made a custom W&B sheet for my M20D available in the downloads section. It is made for Microsoft Excel 2013 and you can edit the blue font numbers (pax, fuel, oil) and it will churn out CG, weight, maneuvering speed, and plot it on a graph. Of course, this is specifically made for my S/N aircraft, but you can edit the numbers as needed for any of the vintage models. If anyone wants a new one for the long bodies, PM me. It is available here: http://mooneyspace.com/files/file/58-m20d-weight-and-balance
That's why I upgraded to a J. I needed room for all those hats that AOPA keeps sending me.
And your useful load is what :-)
if you are android based.  droidefb has a w&B app.   When renting it is nice because you can load lots of planes in it.  at the fuel pump you can play how much fuel should I load or unload.  You could add that to your excel sheet.
