fantom Posted August 22, 2015 Report Posted August 22, 2015 I'm thinking a taxi AND a landing bulb would be a pretty sweet combination. Unless two landing lights would be better. Thoughts? Assuming your night landing was successful, you'll need to taxi, so one of each is the way to go. One wide beam and one narrow one.
Hank Posted August 22, 2015 Report Posted August 22, 2015 Assuming your night landing was successful, you'll need to taxi, so one of each is the way to go. One wide beam and one narrow one. Many of our planes do very well with only one light. Landing it is!
fantom Posted August 22, 2015 Report Posted August 22, 2015 Many of our planes do very well with only one light. Landing it is! So far.......
Hank Posted August 24, 2015 Report Posted August 24, 2015 So far....... It's been a one-light plane since 1970 . . .45 years and counting. Maybe Sabre will put a second light in his new Vintage cowl? If not, she will soldier on with just the one. P.S.--It's a PAR 46 landing light. The newer planes with lights in the wings use the smaller PAR 36; not sure about the J/K airframe, could be either.
Yetti Posted August 24, 2015 Report Posted August 24, 2015 So when I pulled the GE PAR 46 it was mounted upside down and a fair amount of screws in the front bezel were not installed. Being a good person all the screws where replaced. For the PAR46 LED it seems to be aimed a bit high. There are screws on the back side that don't seem to do much. Do you mount the ;ight upside down to change the aim, or the screws on the back supposed to aim housing?
KyleKJ90 Posted August 24, 2015 Report Posted August 24, 2015 My aircraft has several nutplates with screws through the back of them that are "supposed" to aim the beam. I found them to be very rather chincy and the nutplate rivets kept breaking out from all the vibration. I decided to go a different route since the metal ring behind the bulb was almost chaffed through by the screws (once again, from all the vibration). Following a suggestion from a guy at LASAR, I took some pieces of engine baffling and silicone/fusion taped that around the bulb in meticulous places to help reduce the vibration and better aim the beam. Our bulbs have been working for more than a year now without any problems. Aparently some guys change landing light bulbs more than once per year if they're using the regular incandescent ones.
carusoam Posted August 25, 2015 Report Posted August 25, 2015 The only guidance I am aware of is make sure the bulb's element is oriented in the vertical direction. This minimizes the bulb killing gravity assisted vibrations. Or something like that. Best regards, -a-
Guitarmaster Posted August 25, 2015 Report Posted August 25, 2015 I would love to have wing LDG lights. I wonder if I could get that field approved???
MB65E Posted August 26, 2015 Report Posted August 26, 2015 There is a Kit from Mooney to install the twin pack landing lights in the wing like the late models. Then you can worry about cracking or crazing the lense. I remember the kit was not to expensive itself, but the labor would be. Laser, Don or mooney would know. Some one posted the SB Kit number here a long time ago. Good Luck! -Matt 1
charlesual Posted August 26, 2015 Report Posted August 26, 2015 Does anyone know how to setup a wigwag switch for the led lights? Sent from my iPad using Tapatalk
Yetti Posted August 28, 2015 Report Posted August 28, 2015 I have thought about it, but not done it. I would probably use a newer blinker module from a car as there are alternating circuits that blink. If you notice new cars the sides blink opposite the tail lights. Would need a SPDT switch to do all on or have the blinker in the circuit down stream of the on off breaker switch. 1
ArtVandelay Posted August 28, 2015 Report Posted August 28, 2015 Does anyone know how to setup a wigwag switch for the led lights? This handles LED or regular lights: https://preciseflight.com/general-aviation/shop/product/pulselite-general-aviation/
Guest Posted August 28, 2015 Report Posted August 28, 2015 Search for the "Max Pulse" switch from Spruce. It works very well and is simple to install Clarence
