Cwalsh7997 Posted May 1, 2015 Report Posted May 1, 2015 Hey guys on my F model I have a new style prop which apparently is way better than the old fat ones. Anyways during takeoff and on the climb I immediately have to pull the power back because it goes past redline to around 2900rpm which is odd because I would think you want full prop and full power on a climb? I've been told it might just be the prop governor or what not but is it bad to run it over the redline? Quote
OR75 Posted May 1, 2015 Report Posted May 1, 2015 Either the tach is off ( easy to check and fix) or your governor needs to be adjusted ( a little more money) I would not fly untill it is clarified Quote
piperpainter Posted May 1, 2015 Report Posted May 1, 2015 The only issue with running that high is that it can be stressful on the prop when it exceeds the sound barrier. If you need to fly it to a place for adjustment you would be fine. Quote
Bob_Belville Posted May 1, 2015 Report Posted May 1, 2015 If it really is turning 2900 (and not just a bad tach) which is more than 5% and less than 10% overspeed you should read Lycoming's "Mandatory" SB: A logbook entry with any action is required. (For part 91 operations Mandatory may not mean mandatory. ADs are mandatory, SBs "depend".) http://www.lycoming.com/Portals/0/techpublications/servicebulletins/SB%20369C%20%2804-18-2012%29/Engine%20Inspection%20after%20Overspeed.pdf Quote
Guest Posted May 2, 2015 Report Posted May 2, 2015 Here is what Lycoming says about engine over speed issues. http://www.lycoming.com/Portals/0/techpublications/servicebulletins/SB%20369C%20%2804-18-2012%29/Engine%20Inspection%20after%20Overspeed.pdf Clarence Sorry, I missed that Bob posted the sb as well. Quote
ShermAv8tor Posted May 2, 2015 Report Posted May 2, 2015 I caught mine a few times at 2900 (M20C) and I would pull it back immediately to what was indicated as 2700 on the tach. A trip to LASAR and we put the optical tach reader on it using the prop, and turns out at the 2850 on tach, the prop is actually turning 2633 RPM. So my tach needs replacement here in near future. I checked it at different RPM levels on the tach and the higher the revs the bigget the split. So now I know it indicates 150 high above the 2350 redline mark and take it into account. I will get a new tach, just trying to figure out which way I want to go. Get an optical RPM reader and verify the prop RPM. Quote
carusoam Posted May 2, 2015 Report Posted May 2, 2015 The iPhone does pretty good at determining rpm based on sound... Use an rpm app to see how your actual rpm gauge is doing. Know that there is a small oil cup on the back of the old tach. It gets lubed at annual... The tach cable is known to wear out over the decades. Cheap to replace. Best regards, -a- Quote
Guest Posted May 2, 2015 Report Posted May 2, 2015 In Canada a check of the tachometer accuracy is part of the Annual inspection. For those with caution or do not operate range marks on the tachometer this is very important. Clarence Quote
N201MKTurbo Posted May 2, 2015 Report Posted May 2, 2015 Get rid of the mechanical tach. They are nothing but trouble. Quote
