Guys,
After several back and forth I decided that I had enough of electronic ignitions and I am going back to magnetos.
Question: What are the part numbers for Slick Magnetos for the Mooney M20C:? Engine O 360 A1D
Thanks!!!!
Guys,
Thanks!!!!
So are you throwing in the towel completely, or will you try again after returning to the US?
I wish there was a viable electronic ignition system available . . .
Oscar, my O-360-A1D has Bendix mags. The PN for them are: 10-163045-3 & 10-600644-1. Hope this helps.
Hank, yes, I did throw the towel, at least until I am back in the US. My LASAR ignition is dying. I talked to Joe at Champion who has been working with the LASAR ignition for more than 16 years... and his diagnosis was clear. He offered me to send the control box to the factory for them to look at it and tell me if it is broken or not. However, the thinks that the control box is most likely broken and Champion does not fix it anylonger. A new box would cost above 3k, if I could find one. His recommendation was go back to Magnetos. I also tried electroair, but my CHT went through the roof (it was a probe issue) but my local mechanic is now saying that the system is not compatible with Mooneys (Total BS..) and that he would not work on the plane anylonger if I were to install the system. Unfortunately he is the only guy in the country who knows Mooneys.
Overall, I would say that there is a lesson... unless the technology is mature enough, if you move and become an early adopter you may end up without adecuate support....which is what happened to me with LASAR.
So I had it! To say the least I am very frustrated, but I also think that at some point you have to stop trying and stop pushing the boundaries if the capacity is not there. So I decided to go back to magnetos and in the future once I am back in the US I may try electroair again...
  • 3 weeks later...
Well yesterday was my first flight with the new old magneto technology! Everything looks great. CHT normal, Oil temp normal... Back in the air, finally!
When you coming back up to our area? I seem to remember you saying you were back to the DC area.
I flirted with the idea of an electronic ignition briefly and am glad to hear your experience because I was starting to have doubts.
The electronic ignition is nice, its stars well, it runs nicely and it sounds much better than the normal mags. However, you need to have some flexibiilty regarding the CHTs, as it makes the cylinders run hotter. My CHTs are already pretty high with mags, if you add 30 to 40 degrees to the CHT... I was running in the mid to high 400s. I just did not feel confortable with this...
