Cody Stallings is located in Missouri I think and works for a good prop shop. He is a member here on the forum.
Aircraft Propeller Service in Wheeling Illinois, they are across the street from KPWK (Palwaukee Airport)   (847)541-1133, ask for Sean.      I had 2 Props done on Aerostar a while back with good results....no complaints. They Pick up and deliver depending on where you are located.
And travels periodically doing prop dynamic balancing, etc.
I have used the Hartzell factory service facility twice over the years and was pleased both times.  The are located at the airport in Piqua, OH (I 17).  Call ahead for price and appointment.  Both times that I went the gave me an office, WIFI, a car to use to get lunch and completed my work the same day.  They do good work at a fair price.  Toll free number: 877-251-5362
I'm in North Central Arkansas @ 7m2. Stallings Aircraft Propeller is a full service FAA Certified Repairstation, we can handle all of your propeller needs.
What kind of Propeller Issues are you havin Sir? We may be able to get you taken care of right here on MS.
An yes, I do travel an do Dynamic Prop Balance an pickup an delivery to your location.
Feel free to Msg or call me at anytime. 870-208-5198
Yes but... The place in wheeling won't do it without an overhaul because of the age and the fact it had never been done.
I did find shop in Rockford to do it I think.
The wheeling shop did offer to do a Top Prop conversion for $8000. Although it looks cool and goes faster, $8000 is simply out of the question unless that is my only option.
Oh............... Well the First inspection of the hub, the propeller has to be disassembled. ET inspection is then performed on the inside of the hub.
After the reassembly of the propeller, the Ser# will be stamped with an "E", which means it has had the preliminary inspection done. After that the 100hrs inspection intervals begin.
While the propeller is disassembled for the preliminary inspection, it maybe a good idea to Re-seal it at least.
Factory recommends 5yr or 2000hrs on your propeller
I sent you a voice mail. Thanks!
Cody is "The Man" when it comes to props.  For those who don't know, Cody bought out his old company (Mid American Propeller) and is now the sole owner of the new company, Stallings Propeller.  He always takes time to explain what he is doing and why he is doing it.  One nice thing about him is that he will never try to "rip off" any customer.  If you're broke away from your home base,  he can come to you and work on the problem on the spot or take the prop back to his shop for repair.
  • 1 month later...
Just wanted to follow up.
Cody did a great job! Well worth the three hour flight. I can highly recommend him.
The plane is almost as smooth as my 737 now! :)
