LANCECASPER Posted June 9, 2024 Report Posted June 9, 2024 On 3/4/2021 at 10:09 PM, FlyingDude said: Hi guys, Can you reach the floats from the fuel tank feed hole and manually move the floats to see if they are stuck? I had seen my uncle assist a cow give birth... I can use similar gloves that come all the way to your shoulders... Thanks. Did this ever get resolved? Was there a small calf up there obstructing the fuel float? Or maybe a little M10 waiting to be born? Quote
GeeBee Posted June 10, 2024 Report Posted June 10, 2024 Eh, we used one of these if you can get it through the filler hole. Quote
redcatcher27 Posted July 2, 2024 Report Posted July 2, 2024 I tried the amazon borescope with supporting aluminum wire. I was able to fish around to the see the sender that was stuck on the bottom of the tank after the reseal, but was unable to dislodge it. I was pretty much resolved that I was going to have to defuel the tank inorder to be able to see and move around properly with the borescope and wire. Almost in disgust, I tried banging on the bottom of the tank. That worked almost immediately! Banging works!!! Quote
PeteMc Posted July 2, 2024 Report Posted July 2, 2024 22 minutes ago, redcatcher27 said: I tried the amazon borescope with supporting aluminum wire. I was able to fish around to the see the sender that was stuck on the bottom of the tank after the reseal I'd send whomever resealed your tanks the bill for the Amazon borescope!!! 1 Quote
