Anyone know? I think it may be the landing gear actuator? The image is shot with the belly panels off, camera towards the front wheel. The part was almost right above the front wheel (above the front belly panel, of course). I noticed a drop of hydraulic fluid at the bottom of that part, and it does look a bit corroded too. Plane going into annual soon, and I am considering replacing/overhauling it depending on what it is.
Thanks
Stefan
'89 M20 J
post-8980-0-89901200-1372255133_thumb.jp
It looks like the right wheel brake master cylinder and it may be the oring's need replacing. The left is on the other side of the auxiliary fuel pump. the fluid colour red? I just had redone mine this annual.
