Has anyone used or heard positive or negative comments about Savvy Maintenance? They are the company owned by Mike Busch and they oversee the maintenance of your airplane.
I've not used the Savvy Mx program itself.  I've talked with Mike, and been to one of his seminars, and his philosophy on maintenance makes a lot of sense to me.  I would see the program having value if you weren't otherwise very hands-on in your maintenance, or possibly for AOG situations.
They only manage newer planes so you'll need to find out if your plane is eligible. Mine is not.
More specifically, "Savvy reserves the right to decline to manage the maintenance of any aircraft manufactured prior to 1970. We do evaluate these on a case-by-case basis, with strong emphasis on determining whether or not the aircraft still has factory support and parts availability. For example, we will sometimes accept a 60s-vintage Bonanza or Cessna because those aircraft are still well-supported by the manufacturer and most parts are still readily available."
See https://www.savvymx.com/index.php/faq/qualify#old_aircraft for more.
I read that as they are guaranteeing a high level of dispatch reliability. Aka expensive for the type of weekend flying that I intend to do.
Anyone else...?
My IA has unwillingly become the caretaker of a lot of mooneys , He is extremely reasonable , and is getting fiarly well versed in these aircraft.......His shop is the typical messy nowhere to put stuff shop , but he takes care of my Beech and Mooney (owner assisted ) and I have no complaints.....I think I saw Smiles plane in his hangar last night.....
