Attached is a pdf showing some screen shots and comments from playing around with Garmin Pilot on the iPad.
(Sorry I didn't see an easy way of merging screen shots in with text.)
Edit:  I am unable to attach the pdf.  I'll try another appraoch.
I have played around with the Garmin Pilot on my IPad.  It takes a little getting used to (am using Wing X Pro), but I was able to navigate around the app fairly well.  If you get a GDL-39, you'll need to get smart on Garmin Pilot, as this is the only app that it connects to (for now).  The GDL-39 sold very solid at Osh Kosh am I told by several avionics types.
