tls pilot Posted September 11 Report Posted September 11 (edited) The original RPM gauge stopped working after landing. Does anyone know the area where this connects to the engine? Also has anyone used a portable tachmeter inside the plane and if so which one? Spruce sells one for $300.00 Thanks Edited September 11 by tls pilot
N201MKTurbo Posted September 11 Report Posted September 11 I think this tach has a tach generator. I would check the connectors and wiring. The generator will be mounted on the back of the engine.
Fritz1 Posted September 12 Report Posted September 12 On the bravo engine tach pickup is mounted to bottom of the right mag if memory serves, maybe broke off or loose, there is a panel mounted certified RPM gauge that has LEDs, have seen that in Bravos as a patch after the Moritz gauge died and also in Eagles that have the 310hp 2700 RPM STC
tls pilot Posted September 12 Author Report Posted September 12 1 hour ago, Fritz1 said: On the bravo engine tach pickup is mounted to bottom of the right mag if memory serves, maybe broke off or loose, there is a panel mounted certified RPM gauge that has LEDs, have seen that in Bravos as a patch after the Moritz gauge died and also in Eagles that have the 310hp 2700 RPM STC Thank you Yes the sensor pickup is on the mag.
LANCECASPER Posted September 12 Report Posted September 12 3 hours ago, Fritz1 said: On the bravo engine tach pickup is mounted to bottom of the right mag if memory serves, maybe broke off or loose, there is a panel mounted certified RPM gauge that has LEDs, have seen that in Bravos as a patch after the Moritz gauge died and also in Eagles that have the 310hp 2700 RPM STC This is the replacement with LEDs from EI: https://iflyei.com/product/r-1-rpm-tachometer-instrument/
affricate Posted September 13 Report Posted September 13 18 hours ago, LANCECASPER said: This is the replacement with LEDs from EI: https://iflyei.com/product/r-1-rpm-tachometer-instrument/ That's the one installed in my Bravo after the Moritz gauge died, 1
Rick Junkin Posted September 13 Report Posted September 13 On 9/11/2025 at 1:10 PM, tls pilot said: The original RPM gauge stopped working after landing. Does anyone know the area where this connects to the engine? Also has anyone used a portable tachmeter inside the plane and if so which one? Spruce sells one for $300.00 Thanks I have the EI tach removed from my Bravo during the panel replacement in 2023. PM me if you get to the point where you might need it. Cheers, Rick 1
Jetpilot86 Posted Tuesday at 06:13 AM Report Posted Tuesday at 06:13 AM On 9/11/2025 at 12:10 PM, tls pilot said: The original RPM gauge stopped working after landing. Does anyone know the area where this connects to the engine? Also has anyone used a portable tachmeter inside the plane and if so which one? Spruce sells one for $300.00 Thanks Mine started acting crazy and it was a loose plug. Also I have this RPM app for my iPhone and it works great. https://apps.apple.com/us/app/engine-rpm/id340401811
