Vermonter Posted August 3 Report Posted August 3 Looking to see if anyone knows where to possibly buy a dual brake kit for my Mooney M20C, part number 950239-501. I'm going to be flying with friends and family and would like the ability to have a true dual system so they can experience everything from take off to landing while also having control of everything as well.
Hank Posted August 3 Report Posted August 3 I enjoy giving rides in my C, but would not let a non-pilot or even a non-current pilot make the landing. Not even in a trainer, unless a CFI is beside them (which I am not). It is fun to let pax fly the plane, though!
Aerodon Posted August 3 Report Posted August 3 So on a later model M20K without dual brakes: 1) the attachments for the brake master cylinders are in place. 2) change the pedals and arms with a set that has brake pedals 3) install the crossover pipes and T into the existing system 4) bleed the brakes 5) sign the logbook. Some other models - there is a check valve between the LHS and RHS, i am not familiar. M20C, not so sure either. Aerodon 1
Vermonter Posted August 3 Author Report Posted August 3 (edited) 1 hour ago, Aerodon said: So on a later model M20K without dual brakes: 1) the attachments for the brake master cylinders are in place. 2) change the pedals and arms with a set that has brake pedals 3) install the crossover pipes and T into the existing system 4) bleed the brakes 5) sign the logbook. Some other models - there is a check valve between the LHS and RHS, i am not familiar. M20C, not so sure either. Aerodon Appreciate it! Apparently in some of the older forums there are some diagrams kicking around, trying to get my hands on them too. Edited August 3 by Vermonter Didn't select message when replying
Vermonter Posted August 3 Author Report Posted August 3 1 hour ago, Hank said: I enjoy giving rides in my C, but would not let a non-pilot or even a non-current pilot make the landing. Not even in a trainer, unless a CFI is beside them (which I am not). It is fun to let pax fly the plane, though! Agreed, this will be for friends and family that are also active pilots.
