mhoffman Posted June 4, 2025 Report Posted June 4, 2025 Last week while stowing the sun visor on the pilot side of the plane it broke off. Does anyone know where i can find a replacement ?
LANCECASPER Posted June 4, 2025 Report Posted June 4, 2025 7 hours ago, mhoffman said: Last week while stowing the sun visor on the pilot side of the plane it broke off. Does anyone know where i can find a replacement ? If you want a Mooney sun visor with the power chart silk screened on it, check with a Mooney Service Center to see if they are available to order. Otherwise you can order an aftermarket set from @DonMuncy who does a great job making visors.
exM20K Posted June 4, 2025 Report Posted June 4, 2025 2 hours ago, LANCECASPER said: If you want a Mooney sun visor with the power chart silk screened on it, check with a Mooney Service Center to see if they are available to order. Otherwise you can order an aftermarket set from @DonMuncy who does a great job making visors. When a tech broke mine, the shop looked at ordering a new one from the factory, and the single visor was more than a set of Rosen visors. Since @DonMuncy’s visors are more appropriately sized for the Mooney cockpit than are the Rosen visors, I’d go that way if I had to replace one. And if you fly LOP, you don’t need a power chart. An engine monitor and fuel flow gauge is all it takes to set power :-) -dan 1
mike_elliott Posted June 4, 2025 Report Posted June 4, 2025 but you wont have all that lead to "cushion" the valve seats
mhoffman Posted June 4, 2025 Author Report Posted June 4, 2025 Thanks everyone i reached out to @DonMuncy.
