hazek Posted April 22, 2025 Report Posted April 22, 2025 I'm looking to completely refurbish and modernize my Bravo. Does anyone have any good references for this kind of work specifically for Mooney aircraft or in general?
Fritz1 Posted April 28, 2025 Report Posted April 28, 2025 Typically this requires engine, avionics, paint and interior, hardly ever found in one place, Aeromechanica in Switzerland appears to be doing a fair amount of Mooney work, start there and see what they can do, unless you want to fly the bird over the Atlantic
Fly Boomer Posted April 28, 2025 Report Posted April 28, 2025 2 minutes ago, Fritz1 said: Typically this requires engine, avionics, paint and interior, hardly ever found in one place, Aeromechanica in Switzerland appears to be doing a fair amount of Mooney work, start there and see what they can do, unless you want to fly the bird over the Atlantic What happened to Mastenbroek Aeroskill? I never see them mentioned.
hazek Posted May 4, 2025 Author Report Posted May 4, 2025 On 4/28/2025 at 9:01 PM, Fritz1 said: unless you want to fly the bird over the Atlantic I don't no, although I suspect I wont find quality of work as good and the range of options as extensive anywhere else. I'll ask ACG who they recommend for paint and interior. For avionics I've already made up my mind to go to Straubing. On 4/28/2025 at 9:09 PM, Fly Boomer said: What happened to Mastenbroek Aeroskill? I don't know about what happened to them. But I was trying to get my oxygen tank replaced through them and it took 4 months and repeated asking and calling before I finally received a quote. In the end with no response for such a long time I actually gave up on them and I found another solution locally. This was right around the time when they finally did send over a quote but I didn't even respond to them. Perhaps this is the standard that many of these shops have? But I don't find this kind of communication and jerking around appropriate. 1
