Looking to see if anyone has found a source for the Engine Mount Isolator Kit.  I have #17 of the TLS Bravos. 27-0002 through 27-0024 and 27-0026 through 27-0069 use the LORD J-9613-81 kit, while all others use the J-9613-82 kit.  The J-9613-81 kit has been discontinued, so I am trying to get an answer from Parker Hannifin (LORD's parent company) on an alternative.  There is a Barry alternative listed in the part catalog, but they look like a different shape and they are over $800 a piece.  Before I take the plunge on the Barry option, I thought I would reach out to the Bravo forum to see if anyone had seen this issue and found a LORD alternative.
OK, so I finally got ahold of the right SME at LORD.  He confirmed the J9613-81 engine mount kit has been discontinued. All of our TLS Bravos now use the J9613-82 engine mount kit.  It is the same dimensions but uses a somewhat different mixture of rubber.  FYI...I went through all this research because the LORD mounts were over half the cost of the alternative Barry mounts.
