billy hellcat Posted February 5, 2025 Report Posted February 5, 2025 Does anybody know who can service a turn coordinator for a Brittain autopilot? It’s a tc100 Evs. Tried porter strait in Tulsa and they don’t service them anymore. Thanks.
N201MKTurbo Posted February 5, 2025 Report Posted February 5, 2025 http://www.berkshireinstrument.com/price_autopilot3.html https://www.kelleyinstruments.com/capabilities.html
Igor_U Posted February 5, 2025 Report Posted February 5, 2025 Try contact Kevin Westbrook. He was working for Brittain for years and still helps people on the list. Good luck. @Kevin Westbrook 2
Bobaran Posted February 6, 2025 Report Posted February 6, 2025 Try contact Kevin Westbrook. He was working for Brittain for years and still helps people on the list. Good luck. [mention=48565]Kevin Westbrook[/mention]Yes, Kevin used to work for Brittain, building their turn coordinators. These are NOT diy fixit units, so get a professional to fix it. He can fix them but not provide a yellow tag.Sent from my SM-A526U using Tapatalk
corn_flake Posted February 6, 2025 Report Posted February 6, 2025 Yeah, trust me. I tried to repair one my self. As soon as I realized I also had to build a rig to "turn" the coordinator 360 degree with exactly 2 minutes, I say, forget it!! I should let professional handle it. Keven did great work in bring it back alive!!
N201MKTurbo Posted February 6, 2025 Report Posted February 6, 2025 You could build a rate table for about $100 on Amazon.
Kevin Westbrook Posted February 6, 2025 Report Posted February 6, 2025 Billy Kevin Westbrook here call me 539-292-0474 2
corn_flake Posted February 6, 2025 Report Posted February 6, 2025 7 hours ago, N201MKTurbo said: You could build a rate table for about $100 on Amazon. Interesting..... Searching or Rate table come up with nothing. Are you referring to buying parts for DIY rate table? Care the share a picture if you made one?
N201MKTurbo Posted February 6, 2025 Report Posted February 6, 2025 I looked a bit, you can get 5 RPM 12V gear motor for $50. you will need to make some type of turntable and a 10/1 belt drive. I would get a lab power supply to fine tune the speed. You can calibrate it with a stopwatch. Or you can spend big bucks: https://www.ideal-aerosmith.com/products/1-2-or-3-axis-rate-and-positioning-tables/
cliffy Posted February 6, 2025 Report Posted February 6, 2025 1 hour ago, N201MKTurbo said: I looked a bit, you can get 5 RPM 12V gear motor for $50. you will need to make some type of turntable and a 10/1 belt drive. I would get a lab power supply to fine tune the speed. You can calibrate it with a stopwatch. Or you can spend big bucks: https://www.ideal-aerosmith.com/products/1-2-or-3-axis-rate-and-positioning-tables/ Some of you here are way beyond the norm while the rest of us are still hammer, tong and forge!
Rmfriday Posted February 7, 2025 Report Posted February 7, 2025 Call Kevin, he is great with all thing Brittain
