KZNY Posted September 19, 2024 Report Posted September 19, 2024 I am curious to see if anyone had this issue before. The aircraft is a M20J 1998 and if on a pattern and the flaps are engaged for landing at 100kts or above, the 5A breaker pops. The flaps works perfectly at both positions if the speed is 90Kts or below. We have changed the breaker and it was not the issue. Any thoughts or similar experience? Thanks.
PT20J Posted September 19, 2024 Report Posted September 19, 2024 The air load will be higher at the higher airspeed. So, if there is too much friction in the flap system, the added air load from the higher airspeed might be enough to stall the motor and trip the breaker. Or, if something is wrong with the motor so that it doesn’t generate enough torque to operate the flaps, that might trip the breaker. 1
MikeOH Posted September 19, 2024 Report Posted September 19, 2024 Did this just start happening suddenly, or did it start out intermittently and get worse? As PT20J said, too much friction; I'd look to see if everything is properly greased and not binding. Not likely, but could be the circuit breaker going bad; you could 'shot-gun' and replace it, or use a clamp-on DC (NOT AC) ammeter to see what the current draw really is.
N201MKTurbo Posted September 20, 2024 Report Posted September 20, 2024 I would take the flap actuator apart, clean it all up and reassemble it with the moly grease specified for the Dukes gear actuator. While you have it apart check the bearings and brushes in the motor. I would check the amount of current it takes to spin the motor with no load on it. If it is more than 1/2 amp or so your armature is probably fried.
IvanP Posted September 20, 2024 Report Posted September 20, 2024 Sounds like the actuator may need some care. I agree with Skip's suggestion above. May need new brushes. 1
KZNY Posted September 20, 2024 Author Report Posted September 20, 2024 Thanks a lot. I will have the maintenance folks cleanup and grease the actuator assembly. Will see what shakes out. 1
Utah20Gflyer Posted September 22, 2024 Report Posted September 22, 2024 Sounds like your flap system might need some attention and as an owner of a hydraulic flap Mooney I don’t have much to add on troubleshooting an electric flap Mooney. I would however question why you would put out flaps at 100 kts or even higher. Seems like that’s a bit fast. 90kts is a nice pattern speed for a mid body Mooney, and also works well as an approach speed. Putting out flaps and gear at higher speeds creates a lot of extra wear and tear on the systems. Ultimately it’s your plane so it’s your choice and I’m not saying people are wrong if they choose to operate their airplane differently than I operate mine. There are however benefits to slowing down in the pattern and one of them is less wear and tear on the airframe.
dzeleski Posted September 22, 2024 Report Posted September 22, 2024 2 hours ago, Utah20Gflyer said: Sounds like your flap system might need some attention and as an owner of a hydraulic flap Mooney I don’t have much to add on troubleshooting an electric flap Mooney. I would however question why you would put out flaps at 100 kts or even higher. Seems like that’s a bit fast. 90kts is a nice pattern speed for a mid body Mooney, and also works well as an approach speed. Putting out flaps and gear at higher speeds creates a lot of extra wear and tear on the systems. Ultimately it’s your plane so it’s your choice and I’m not saying people are wrong if they choose to operate their airplane differently than I operate mine. There are however benefits to slowing down in the pattern and one of them is less wear and tear on the airframe. The early Js have a Vfe of 125mph (108kts) and a Vlo/le of 150mph (130kts). The later Js I believe are even higher than that.
Fly Boomer Posted September 22, 2024 Report Posted September 22, 2024 1 hour ago, dzeleski said: The early Js have a Vfe of 125mph (108kts) and a Vlo/le of 150mph (130kts). The later Js I believe are even higher than that. POH 1233 says 15 degrees at 132, and full flaps at 115. Doesn't seem like 100 is "too high".
dzeleski Posted September 22, 2024 Report Posted September 22, 2024 6 minutes ago, Fly Boomer said: POH 1233 says 15 degrees at 132, and full flaps at 115. Doesn't seem like 100 is "too high". That’s what I was trying to get at. I agree with you, nothing wrong with putting them in at the top of the range. 1
Fly Boomer Posted September 22, 2024 Report Posted September 22, 2024 1 minute ago, dzeleski said: That’s what I was trying to get at. I agree with you, nothing wrong with putting them in at the top of the range. Understand. I don't really know if POH 1233 is early or late. It was just another data point I had available. 1
dzeleski Posted September 22, 2024 Report Posted September 22, 2024 1 hour ago, Fly Boomer said: Understand. I don't really know if POH 1233 is early or late. It was just another data point I had available. My 77 doesn’t have that, I have one speed and that’s it. I believe that later POH is from the 205 specifically. 1
KZNY Posted September 23, 2024 Author Report Posted September 23, 2024 According to POH 3203, the max Vfe KIAS with flaps extended is 112 and 109 (KCAS) - White Arc. One observation was that when the flaps were put in above 90 kts, the flaps barely travelled to the TO position but 2-3 secs later the breaker pops. It’s like the motor is trying and in the process drawing more current. At 90kts or below, they work perfectly fine. Will have the Maintenance folks take a look at the actuator assy for grease hardened or other build up 1
PT20J Posted September 23, 2024 Report Posted September 23, 2024 All the M20Js have a max full flap speed of 110 KIAS per the TCDS. The maximum speed for 15-degree flap deflection is not specified EXCEPT for S/N 24-3000 through 24-3078 (which were the short-lived 205s) where it is listed as 126 KIAS. There appear to be minor unexplained differences in some of the POH.
