Grant_Waite Posted July 31, 2024 Report Posted July 31, 2024 Looking to see if anyone knows where I can find this part? It’s listed as D222 Stop, Wire in the IPC. I can’t find anything when I look for the name. It’s number 43 on the landing gear actuator and emergency extension page. Here’s some better pictures I found in the service manual of what it looks like Quote
Fly Boomer Posted July 31, 2024 Report Posted July 31, 2024 Similar: https://www.autozone.com/collision-body-parts-and-hardware/cable-stop-clamp/p/dorman-help-1-8in-cable-stop/82343_0_0 Quote
N201MKTurbo Posted July 31, 2024 Report Posted July 31, 2024 If you prefer the aviation isle at Aircraft Spruce instead of Auto Zone: https://www.aircraftspruce.com/catalog/appages/wirestop.php 2 Quote
Grant_Waite Posted July 31, 2024 Author Report Posted July 31, 2024 I ordered 2 different types from AS last night. The one you sent me and another type. I figure a cable stop is a cable stop. And one from aircraft spruce should be just as good as what Mooney used right? Quote
N201MKTurbo Posted July 31, 2024 Report Posted July 31, 2024 1 hour ago, Grant_Waite said: I ordered 2 different types from AS last night. The one you sent me and another type. I figure a cable stop is a cable stop. And one from aircraft spruce should be just as good as what Mooney used right? Works for me. You can consider it a standard part. As an IA, I wouldn't give it a second look as long as it is doing its job. 1 Quote
Grant_Waite Posted July 31, 2024 Author Report Posted July 31, 2024 2 hours ago, N201MKTurbo said: Works for me. You can consider it a standard part. As an IA, I wouldn't give it a second look as long as it is doing its job. Yeah, it drives me nuts trying to search for some of these parts with outdated numbers. Or no number at all. Quote
N201MKTurbo Posted July 31, 2024 Report Posted July 31, 2024 2 minutes ago, Grant_Waite said: Yeah, it drives me nuts trying to search for some of these parts with outdated numbers. Or no number at all. I can usually find most of the OEM part numbers in the parts manual, but I couldn’t find this one. Quote
Grant_Waite Posted July 31, 2024 Author Report Posted July 31, 2024 1 hour ago, N201MKTurbo said: I can usually find most of the OEM part numbers in the parts manual, but I couldn’t find this one. Yeah this one was quite tough. I just received my few parts from BAS that I needed. Still waiting for Lasar to get my gear new and old gear motor Quote
