I am getting an audible beeping tone. I can’t yet correlate it with my speed but I suspect it is a gear warning or over speed alert. Does anyone know what this is?  Thanks
Can you give us a little more here? When does this happen would be a great start. Is your plane new to you? How long has this been happening?
Pull circuit breakers until it stops. That should help identify it. Can you hear it in headphones, or is it a sonalert?
Mooney uses an intermittent tone for the gear warning to distinguish it from the stall warning. You might heck the throttle switch adjustment.
My stall warning sounded continuously one year right after annual. The IA had not taped over the static vents before washing the plane, they had water in them.
As @PT20J said, there’s a gear warning switch on your throttle. Normally, it’s only activated with the gear up and the throttle near idle. If you pull the gear warning, circuit breaker, it should stop. If that’s it, you should be able to adjust the switch on the throttle.
Okay it sounds like the gear warning. I think it goes away when I lower the gear. It’s not the stall warning. I will pull the breaker tomorrow!
If it’s the gear warning, a likely place for the issue is the little switch on the back of the throttle.  Maybe needs adjustment or some lube.
if it is the gear warning, normal should sound like a very annoying sound that gets your attention (not just an audible beeping)
