Pinecone Posted September 3, 2024 Report Posted September 3, 2024 In my perfect airplane, there would be two busses. Essential and Other. Essential would be alt and batt. Other would only be alternator powered.
super-fly Posted October 5, 2024 Report Posted October 5, 2024 On 1/25/2024 at 12:35 AM, Utah20Gflyer said: I understand you pick up 20 lb +/- useful load by making the switch. That’s interesting to me. There is current approval for IO360 powered airplanes which have the battery behind the baggage area, but not for O 360 powered airplanes like mine that have the battery forward of the firewall. Would my M20C be approved since the battery is now behind the baggage area due to the LASAR cowl mod, or is it not approved due to where it was when it left the factory? I have a serious aft CG problem, and removing 20lb from the tail would be a huge help.
Shadrach Posted October 5, 2024 Report Posted October 5, 2024 1 minute ago, super-fly said: Would my M20C be approved since the battery is now behind the baggage area due to the LASAR cowl mod, or is it not approved due to where it was when it left the factory? I have a serious aft CG problem, and removing 20lb from the tail would be a huge help. If you have a “serious” aft CG problem, I would be skeptical of the calculations. 1
Utah20Gflyer Posted October 5, 2024 Report Posted October 5, 2024 18 minutes ago, super-fly said: Would my M20C be approved since the battery is now behind the baggage area due to the LASAR cowl mod, or is it not approved due to where it was when it left the factory? I have a serious aft CG problem, and removing 20lb from the tail would be a huge help. This something you’d have to discuss with your IA. The STC wouldn’t apply to your plane but it may be possible to do it with a 337 since your planes battery set up is now like the aircraft the STC does apply to.
FlyingDude Posted October 5, 2024 Report Posted October 5, 2024 Just turn off the alternator field in flight and you'll read the actual current draw instantly .
