gwav8or Posted September 29, 2023 Report Posted September 29, 2023 (edited) Well I don’t like this. My F just came out of annual. Went to fly this morning and in start up the MP was showing 0” at idle. Ran up to 1900 RPM and the MP only came up to about 14”. Ran up to 2300 RPM and only got up to around 19”. When I pulled the throttle back to idle the MP actually went negative. Less than 0”. Mechanic told me that the MP line was loose at one of the fittings so he reflared the line and reattached during annual. What the heck? I’ll upload some pics and a video when I get back to my computer. EDIT - I can't attach a video, but when we removed the MP line from the firewall side it read normal. I'm guessing it's a plugged MP line. EDIT #2 - Adding pics Sent from my iPhone using Tapatalk Edited September 29, 2023 by gwav8or
N201MKTurbo Posted September 29, 2023 Report Posted September 29, 2023 I would remove the MP line at the firewall on the engine side. If it doesn't read ambient pressure, then remove the MP line at the gauge, and see if it reads ambient. If the gauge does read ambient pressure, then remove the line from the engine and firewall and blow through it and see if it is clogged. 1
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 Yeah, when we removed the line it read normal. When we were troubleshooting the baro was 29.99 and when the MP line was disconnected the MP was reading about 29" which I believe would be normal. Reconnect and the MP dropped to about 13" with the RPM around 1800. So hopefully just a clogged line and blowing it out will fix.
takair Posted September 29, 2023 Report Posted September 29, 2023 At least on the early E models, there is a tiny bleed hole in the line. Was never quite sure if it was for pulsations, calibration etc. However, he may have clamped that under an Adel or entirely eliminated it. That alone might delay ambient when engine not running… 1
PT20J Posted September 29, 2023 Report Posted September 29, 2023 There should be a small weep hole at the low point of the line to drain moisture. 1
Dialed In Posted September 29, 2023 Report Posted September 29, 2023 Do you have a mechanical gauge or digital?
Dialed In Posted September 29, 2023 Report Posted September 29, 2023 You can see the weep hole on my manifold pressure line at the top by a small dab of silicone if you zoom in. I think most are further down by the intake.
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 40 minutes ago, Dialed In said: Do you have a mechanical gauge or digital? Mechanical
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 37 minutes ago, Dialed In said: You can see the weep hole on my manifold pressure line at the top by a small dab of silicone if you zoom in. I think most are further down by the intake. Yep I see the weep hole on yours. Mine doesn't have a weep hole that I can see and the MP line isn't the same as yours. On mine, aft of the blue fitting (not sure what it's called) is a small rigid aluminum (I believe aluminum) hose/tube. Like very small. Probably 1/8" or smaller. I added a pic of the one on mine to my original post.
carusoam Posted September 29, 2023 Report Posted September 29, 2023 All of the mechanical MP gauges have a weep hole… That lives in the 1/8” line about 1” from the gauge… it is a calibrated hole with a tiny diameter… All the vibration on an unsupported, soft, aluminum tube… causes cracks to form at the hole… This all takes about 40 years to happen… cut, the end off, drill new hole, reconnect… The dimensions of the weep hole is in one drawing, but not all… in the instruments section of the maintenance manual… I was looking in the M20C drawing, but was pointed to the M20F(?) drawing…. My second call to the Mooney factory in Y2K or so…. The engineer (Bill Wheat) was incredibly helpful. Trying to measure the broken hole is a real challenge… Accurate MP readings depends on the calibrated aspect of the weep hole… Getting the drill bit… takes time to get shipped… unless you have a really good tool store nearby…. See how much an EI MP gauge costs for comparison… no weep hole required. PP thoughts only, not a mechanic… Best regards, -a-
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 All of the mechanical MP gauges have a weep hole… That lives in the 1/8” line about 1” from the gauge… it is a calibrated hole with a tiny diameter… All the vibration on an unsupported, soft, aluminum tube… causes cracks to form at the hole… This all takes about 40 years to happen… cut, the end off, drill new hole, reconnect… The dimensions of the weep hole is in one drawing, but not all… in the instruments section of the maintenance manual… I was looking in the M20C drawing, but was pointed to the M20F(?) drawing…. My second call to the Mooney factory in Y2K or so…. The engineer (Bill Wheat) was incredibly helpful. Trying to measure the broken hole is a real challenge… Accurate MP readings depends on the calibrated aspect of the weep hole… Getting the drill bit… takes time to get shipped… unless you have a really good tool store nearby…. See how much an EI MP gauge costs for comparison… no weep hole required. PP thoughts only, not a mechanic… Best regards, -a-This is probably the way to go but….. Mine is the MP/FP combo so I’d probably be looking at the CGR-30P Premium. At a “premium” price too. Sent from my iPhone using Tapatalk 1
carusoam Posted September 29, 2023 Report Posted September 29, 2023 @gwav8or, You just received the ‘need’ for a great upgrade…. we have the EI guy around here if you have questions… Best regards, -a-
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 1 hour ago, carusoam said: @gwav8or, You just received the ‘need’ for a great upgrade…. we have the EI guy around here if you have questions… Best regards, -a- @carusoam Yes, this is very true. I'll be taking the Mooney in the next week or two to have avionics installed. I've committed to going the engine monitor route as the next upgrade. I may consult with my CFO (wife) and see if we can squeeze a few more AMUs out of the budget. :-) I really love this plane and really honestly wish I'd joined the Mooney club/cult two airplanes ago.
gwav8or Posted September 29, 2023 Author Report Posted September 29, 2023 BTW, problem solved. Mechanic removed the MP tube (what is the correct term??) and found some debris. Just got back from maintenance flight and all seems to be good now. Thanks All! 1
