I have the 27.4 gal/ side Griggs bladders in my C.  The fuel drain valve on one side just started leaking pretty briskly. I believe the part is distinct from the valves on the factory wet wing.  I don’t think it’s sediment holding the valve open - tried to clear it multiple times without success.  I suspect the o-ring is toast.  Anyone have the right part number to replace the o-ring or the whole valve as necessary?  Anything else I might be missing here?
All I will say is use proper torque fitting putting the new one in or you will twist it off, not that I would have any experience with that….
I had an errant clamp that nicked the nipple on the bladder, causing a leak. Had to send the tank in for repair. Hope yours is simpler.
  • Sad 1
Need more information, are you saying there is a special tool, or are you saying don’t overtighten?
Don’t over tighten the brass is a little fragile.
Fixed!  thank goodness it was the drain valve and not the nipple of the bladder or some other source.   Here’s the part for future reference for bladder owners:
F-391-18
Think the part number is written on the face of those.   This is not a tractor tight application of torque.   Snug it and bit.
I think so - it was a bit tough to read when 100LL was dripping in my eyeball though :lol:
